Adding Bose sub woffer
Old Apr 24, 2017 | 04:49 AM
Scottcolem's Avatar
Scottcolem
Default Adding Bose sub woffer
can the sub be added to the 9 speaker system? thanks
Old Apr 24, 2017 | 09:27 PM
upcharger's Avatar
upcharger
I'm interested in this as well. The 1LZ radio sucks. And I haven't been able to find much after market.
Old Apr 24, 2017 | 10:00 PM
Scottcolem's Avatar
Scottcolem
I cant find any aftermarket either. I do know that the 10 speaker system uses a different amp. ive been able to find all the parts on ebay, but it would be a 500 dollar paper weight for all the parts if it doesn't work
Old Apr 24, 2017 | 10:07 PM
Sicotic's Avatar
Sicotic
You can do whatever you want with the speakers. Add an amp, etc. The sky is the limit.
The head unit is the problem. Hard to find a good one without losing functionality.
Old Apr 25, 2017 | 07:27 AM
MP&RPZ06's Avatar
MP&RPZ06
I looked into this also. Other than the amp and rear sub woofer with panel the hardest thing to sure up was the wire harness. I put it on hold until more information is available.
Old Apr 25, 2017 | 10:52 AM
docb's Avatar
docb
Do you know this for a fact? My long term installer has said that the noise cancellation screws up if there are aftermarket speakers in the signal path. I was able to add an aftermarket sub with a mono block amp with no issues.
To Adding Bose sub woffer
