Knock light
Old May 15, 2018 | 09:05 PM
lordofwar's Avatar
lordofwar
Originally Posted by DAVE396LT1
Given that everything I've read indicates our cars have to pull timing with 92 octane once they warm up, sometimes I wish I had a light on the dash to indicate knock. By that I mean a light that lights up when the computer has heard knock and is going to pull timing - so that it'd flicker or flash with each knock detection event, or light up if it were constant.
I can think of two ways - the first is simpler if possible, hooking into the knock sensor circuit itself somehow.
The second would be to monitor the datastream on the ALDL port like a little mini scan tool that then lights up an LED. That'd take a little bit of hardware, but is likely safer.
Has anyone heard of any pre-existing solutions or products that do anything similar? I found this MSD product, but you'd need a bung to screw it into the block, and I'm not even sure we have a spare hole!
https://www.summitracing.com/parts/msd-8964
my question is why would you want to know,and if you know you need higher octane gas,cant you just use 93 octane gas?or if you cant get 93,just put in a additive like Klotz to fix the problem.just trying yo understand your point of view on this.
Old May 15, 2018 | 09:13 PM
Higgs Boson's Avatar
Higgs Boson
So what -would- be an appropriate parameter to watch in the DIC with a DashLogic to be informed about knock?
I actually above thought you could watch knock COUNT, which I assumed to be how much knock it saw, not the amount of retard. Wouldn't that work?
Knock count doesn't -mean- it's pulling timing yet, but it does tell you something about what the engine is "hearing" for knock, doesn't it? And it should be separate from traction management and torque management and so on...
the best thing you can try to watch is knock sensor voltage to see only knock sensor activity. HPTuners doesn't have a functional PID for knock sensor voltage currently on GenV PCMs, at least not last time I checked. that probably means the pid just isn't there for the E92 from GM.
older GM stuff and other makes do have it.
Old May 15, 2018 | 09:16 PM
Higgs Boson
as mentioned earlier by dar, knock will learn down. if you have been driving around in your car for any meaningful amount of time then you will log no knock as it has already learned down. with HPT the easiest way to log knock and adjust accordingly is to make the high and low tables the same and you know that it won't learn down then. you can shape your high table that way without interference from knock learn.
Old May 16, 2018 | 09:30 AM
cdh027's Avatar
cdh027
I would want to know that if I'm getting knock retard and I do something to remedy it that it is working. I would want to see the computer going from retard to advanced if I put better gas in or octane booster. I had an issue with knock retard in my GT500 that wasnt resolved with 100 octane gas and I was able to know this by monitoring that.
Old May 16, 2018 | 10:24 AM
Higgs Boson
the spark logic doesn't work like fords, just an fyi.
Old May 16, 2018 | 10:30 AM
cdh027's Avatar
cdh027
I did not know that. Please explain?
