Fasterproms Expansion Tank DIY with pictures
Hello everyone,
Wanted to take some time a do a writeup on the install on the Fasterproms Expansion tank for the Z06.
First an foremost the expansion tank fit and finish is 10/10. Perfect. Amazing job Fasterproms team.
Ok so first what you want to do is unbox everything and gather all the tools stated in the instructions, very easy install minus one part that I personally had trouble with, which I will mention later.
Next what you want to do is remove the fluid exit ring and hose from the supercharger, keep in mind than fluid WILL leak out have some shop towels ready.
Next you want to remove the bolt by the vacuum pump shown in the picture below:
Next dry fit the tank and make sure it lines up the way it is intended and keep in mind under the front of the tank there are some OEM wires try to route them as best as possible so the tank is able to touch the mounting points. once the is done align the mounting positions and mount the tank securely to the car.
Also remove this oil line, it will be easier to install the hose.
Now fit the hose supplied for the tank feed line mount the top side oring and cut the bottom accordingly. When installing the oring i managed to fit it between the hose and supercharger, fits perfect and is secure.
For the next part i found it easier to remove the driver side hood lift support from the hood.
now you can remove the hose that feeds the heat exchanger, this was the hard part for me, its a tight fit for your hand so you will likely have to get a long pair of needle-nose pliers to do this.
now cut about 6 inches from the heat exchanger side and then put it back, then i zip tied it to the original looping point and routed it back to the exit off the tank and cut a little more from the expansion tank exit side.
now all you have to do is route the drain line to the bottom of the car, I routed it through the driver side fender under the headlight and it came down all the way to the triangle hole in front of the driver side wheels, instead of letting it hang freely I drilled a hole next to the triangular hole and pushed the drain hose through there, came out nicely and its easy to put a pan under and drain.
All Done!!
Hope this helped.
Regards,
Eddie
All Done!!
Hope this helped.
Regards,
Eddie
rw99 (04-27-2017)
thank u!
Absolutely,
Car was at 110 iat2 after back to back passes at pbir recently in the south florida heat.
Ran literally back to back at a private event, and the car hit consistent times of 9.8 - 9.9 in the quarter mile without skipping a beat.
It does its job very well.
onfire (04-27-2017)
I'm using the same tank and I like how you drilled the hole for the drain line. Are you using the thermal plates also?
That is impressive. What would you have expected iat2 on a stock tank ? ice used ?
I don't think IAT2 is correct in HPT for our cars...Its way too cool
Thanks for the write up and pics of the install on the reservoir. That will help a lot of people out.
Any issue getting the system bled?
Before this tank I had the plastic edlebrock tank and iat2s were at 130-140. The last time I was at the track ice was used, but by the end of the first pass ice was melted and the back to back passes were still low.
Very easy to drain. All I did was cut the gallon jug of distilled water I was using and slide it under the bumper then drained and refilled. Just make sure you fill to the very very top of the tank to avoid air and cavitation.
You must fill up the tank before restarting the car anyway, and the recommendation from fasterproms is to fill within half an inch from the top. In stock trim the intercooler pump does not work until intake air temperature has reached a given threshold and a given amount of time has transpired.
If air gets into the system the intercooler pump will stop working. The reservoir allows for air to separate and rise to the top where it draws from the bottom which of course is all liquid.
The tank is very easy to evaluate in my opinion, I purchased the tank because in my opinion it is the best one on the market.
Easy to fill, ice compatible, easy to drain, extra cooling capacity, and amazing quality.
For easy comparison you can relate to boiling water for macaroni, lol. The more water you put in a pot for boiling macaroni the longer it will take to boil, right? Same concept here, adding fluid capacity to the blower the longer it will take to heat up. The water has to reach its heat capacity before it can start changing its temperature, so by having all that extra fluid it will take longer to heat up, and because you have all that extra fluid it will be easier to cool down also.
I use distilled water and a bottle of redline water wetter, this is because I never see freezing temps in south Florida. If you are in a climate that has freezing temps I would def use some dexcool-antifreeze.
Water has had a specific heat value of over 4.0 which is very high, which is hard to heat up and easy to cool, you can do 50-50 distilled water and dexcool if you have freezing climates, otherwise I would go all distilled water and a bottle of water wetter. (Maybe even 5-10 % dexcool if you want to give it a little "lube" so to speak, lol.
MrBlackZ06 (04-27-2017)
Side note: I have a brand new never installed faterproms tank I will sell for $400 if anyone is interested
Silvah Goat (11-27-2018)
