Z06 exhaust
Enz512tr (05-21-2017)
When in Sport or Track mod the NPP valves are open. Most of the exhaust flow is directed to the outer two tips. It's completely normal.
7th Gear
Z06 exhaust
Thanks for your reply. Also thanks to "OnFire". Got my 17 Z06 about a month ago and figured it had something to do with the valves. I've set the exhaust sound for Track all the time. Have also heard that I can remove fuse 42. If I do that, will the exhaust be evenly distributed through all four pipes or is it simply due to path of least resistance with most exhaust going through the outside pipes?
No. Mine is pulled. It does help the baffles stay open all the time instead of closing a bit when shifting.
Doesn't help distribute. Outer 2 are always dirty after a drive. Inner 2 clean for days n weeks.
I've decided to paint mine black this weekend. Sick of cleaning them.
Funny, I have the Corsa set-up, which deletes the NPP, and all 4 tips are equally dirty.
Enz512tr (05-22-2017)
