Off to the dyno for this twin turbo experiment
We don't seem to have an "other tinkerings" section and the off-topic section is a dark and scary place, so I'll just post this here and take my chances! It's not my Z06, but at least it's a Chevy.
This is the 502 I pulled out of my 69 Camaro when I put the LS3 in it (you may remember the law that said all 1969 Camaros had to be converted to ZZ502s was later changed to be an LS motor).
I decided to see what I could do with eBay and thousand dollars. I went over that by a little, but not too much. I added two GT45 turbos, manifolds, intercooler a pipe kit, two bypass valves, a blowoff valve, and some misc hardware to build what is pictured below.
I have no idea if it'll hold together, whether I'll get a turbine in my forehead or what'll happen, but we dyno it today!
My fuel system is going to be limited to about 1200hp (85# injectors, that's my back of the envelope guess). I really only hope to make 1000 ft-lb, that's the goal.
It's running a BS3 computer on a 3 Bar map and I'm going to dyno it on "5 gallons plus a can of Race Gas Concentrate" which should put me at about 104 octane.
No plans to put it in a car, but a 71 Monte SS would have a lot of room under the hood...
SpeedyD (05-24-2017)
Sadly, one of the turbos leaked oil hugely into the hot side, smoking out the valley around the dyno shop! So back to eBay for another $200 turbo, as they're not worth fixing. Apparently you do get what you pay for! They do lay over at about a 20-30 degree angle which -could- cause oil leaks, but this wasn't a little leak, it's like it wasn't sealed at all.
The engine is quality, the induction is not. Rough specs:
GM ZZ502 short block, forged parts
Trick Flow 340cc Rect port CNC heads, raised exhaust ports
Hogan Sheet Metal intake
10-16psi boost
10-16psi boost
