Injectors
Old Jun 12, 2017 | 09:35 AM
Brent Bowling's Avatar
Brent Bowling
Default Injectors
Hey guys, I've been trying to do a bit of research but haven't found much on the topic. Is everyone swapping Injectors once they reach a certain HP? I'm running e85 and haven't been able to even find what HP the z06 stock Injectors max at.
Old Jun 12, 2017 | 10:25 AM
eric04's Avatar
eric04
Old Jun 12, 2017 | 10:26 AM
davepl's Avatar
davepl
Nope. And the stock injectors are not large enough to support any mods with e85... and the fuel system does max out pretty early as the power comes up.
I'm not in that crowd, but my understanding is most people are running a port-injection style of meth for additional fueling under load. I don't know how reliable or how carefully metered that is.
Others have tried different pump lobes and so on to generate more fuel from the stock pump/injectors, including different lobe styles and shapes as well (with more strokes per rotation even).
I have not seen a solution that made me want to step up with my handful of cash yet...
Old Jun 12, 2017 | 10:57 AM
Brent Bowling
Well damn. I've seen an article about the injectors being able to handle upwards of 900 hp on e with certain cam upgrades but wasn't sure on how true it was since I never see anyone talk about it. Seems like most people are running meth, I was just hoping to avoid it. I like taking the car for road trips so hauling meth around just doesn't seem practical. They need to step up their game on after market injectors.
Old Jun 12, 2017 | 11:00 AM
davepl's Avatar
davepl
I think someone did (Lingenfelter perhaps?) but if I recall the increase was modest, like 15% more flow or something like that. Not enough for me to remember thinking "Well, the injector problems are solved". And they weren't cheap!
Old Jun 12, 2017 | 11:05 AM
Brent Bowling
Yea, I think I had found two after market injectors that apparently work well, but not enough of an increase. And wouldn't be so bad if there weren't 8 of them you had to swap out.
Old Jun 12, 2017 | 11:10 AM
eric04's Avatar
eric04
what LB is the current injector?
Old Jun 12, 2017 | 11:34 AM
Brent Bowling
Nope clue, tried doing some research over them but didn't find much... It's as if no one has been swapping Injectors, and I know I'm not the only one with an LT4 running e...
Old Jun 12, 2017 | 12:57 PM
mtaylor's Avatar
mtaylor
Hopefully the new zr1 will get some upgraded injectors that you'll be able to swap to the z at a reasonable price.
Old Jun 12, 2017 | 01:00 PM
Brent Bowling
That or I may have to just bite the bullet and start running meth. Would love to keep running E but no point if injectors can't put out.
Old Jun 12, 2017 | 01:52 PM
BooSSted's Avatar
BooSSted
HOPEFULLY the ZR1 parts are a true upgrade and are directly replacements...
Katech: 12-15%
Lingenfelter: 30%
FIC: 30%
At half the flow the Katech units are half the price of the FIC/LPE..
I think it was Cunningham Motorsports or CPR was pushing the new FORE triple pump, add that with FIC injectors, and a Cam you could finally push enough E85 to not rely soley on meth. But you're also talking $10+K in fuel mods alone, I'll keep the meth until more options are avaliable. Road trips wont be an issue if you stay out of the boost. Plan ahead and find a speed shop if you're addicted to it
Old Jun 12, 2017 | 02:03 PM
Brent Bowling
Katech: 12-15%
Lingenfelter: 30%
FIC: 30%
So sounds to me like 93 and meth will be my best bet. Kinda wish I wouldn't have thrown in a flex fuel kit now, unless if the ZR1 injectors are badass. Well, guess I better start my search for meth kits now.
Old Jun 12, 2017 | 02:09 PM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
liii
Old Jun 12, 2017 | 02:12 PM
Brent Bowling
Katech: 12-15%
Lingenfelter: 30%
FIC: 30%
Originally Posted by sammy burks
Comp BT cam for the LT4 comes with 38% fuel lob
Yup. I'd seen the LT4 injectors were apparently good for upupwards of 900 hp on e85 with the 38% comp cam. Never see anyone talking about it though, so not sure how reliable that info is.
Old Jun 12, 2017 | 02:14 PM
Blue02ws6's Avatar
Blue02ws6
There are tons of builds with minor mods (headers, pulley, intake etc.)with E85 mixtures with stock cam and injectors, just not 100% e85. You can do 100% e85 with meth though with stock injectors.
Old Jun 12, 2017 | 02:16 PM
Brent Bowling
I'm not too familiar with meth since I've never used it, but how does it decrease the amount of fuel needed for injection?
Old Jun 12, 2017 | 02:31 PM
Blue02ws6's Avatar
Blue02ws6
If you don't mind mixing e85 with 91-93 then you can easily run E30-E40 with mild mods up to about 700rwhp and still gain all the benefits of E85. If you don't want the hassle of mixing E85 with premium gas then you will need meth to use 100% E85 to compensate fuel requirements unless you do a low side fuel upgrade or cam and injectors. Meth is just a progressively controlled injection of methanol to aid in fueling when under boost. There are tons of articles online and around here on it. A meth kit is about $600 but labor to install will be high unless you do it yourself and then a tune for it. Cam and injectors would be MUCH more expensive but if you don't get crazy with mods you can just mix E85 with premium for a low blend and still be fine. Read read read, there is tons of info out there, I'm not an expert by any means but I read everything I can get my hands on and listen to the guys I notice that are very knowledgeable on the subject.
Old Jun 12, 2017 | 02:49 PM
onfire's Avatar
onfire
Lingenfelter ftw.
Old Jun 12, 2017 | 02:50 PM
Cordes Performance Racing's Avatar
Supporting Vendor
there isn't enough high side pump to support much over 800 rwhp on e85 unless you have so many meth nozzles it looks like a purple C7...
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
To Injectors
