Bit by the overheating bug
I'm paraphrasing, because I was Sh**ing a brick, and I didn't get a picture of the DIC.
This occurred after driving for only 5 minutes. Air temp was only 79 degrees and I had 10,125 miles on the car. Two hard turns and hard (but not WOT) acceleration in between, and after the third turn I got the DIC warnings and the car went limp. Luckily, I was on a back industrial road and pulled off and did a U turn to stay away from main roads. Man, that would be crazy scary at speed with other cars around on the track.
My Vette drove like it was powered by 2 cylinders, with maybe no power steering. Very sluggish. I went to cross an intersection with oncoming traffic and I was concerned it wasn't going to make it across. Sincerely.
I pulled into a parking lot and sat in the shade and turned the car off. After five minutes it restarted. Normal engine power but engine light remains.
So looks like I have a visit to the dealer in my future. Is there's something they need to reset, since the engine light remains?
Awesome.
Last edited by Steve Garrett; Jul 2, 2017 at 06:13 PM. Reason: Merged Posts-please use the Multi-Quote button (the middle icon) in the lower right hand corner of each post to make your responses look like this!
Could have been a glitch (unless you are able to somehow measure the actual water/oil temps to verify the computer is correct) or there is a computer/sensor problem.
I wouldn't stress about it at all and let the dealer check out the system, it is probably something very minor.
Just my 2 cents on the issue.
Hope so...goes in to the dealer in about an hour.
I don't think sitting in the shade is the best way to cool off an engine..
Not sure what the dealer is gonna do. "Well, it's not hot now is it?? Then you're good!" Maybe clear the code and joyride it for a bit..
If it happened with normal coolant temp 190-220 range, then it's not an "overheating bug" at all but an electrical/software glitch.
For what ever reason, the car though it was overheating(and it well may have been heading in that direction, if not already there) and put the driver in a serious situation as the car basically shut itself off. That can lead to serious problems in traffic, etc, on a public high speed highway.
Not the first, and I doubt the last, we have heard of this problem manifesting itself with the 2015/2016 Z06. Seems I heard that there is a class action lawsuit against GM for this problem.
There are a few different scenarios that people are lumping together.
1. The lawsuit is about a design issue (and components are working as designed) and car overheats when pushed. This usually only happens on the road course with an A8 Z06.
2. A different issue is failure of a component causing an actual overheat condition; broken water pump, bad thermostat, leak, and etc.
3. The first two issues will show a warning as indicated in this thread. A third issue, which does not show a warning on the dash is a mis-performing intercooler circuit (Charge Air Cooling/CAC) which will de-rate power but will not show a warning message on the DIC. This issue can happen for a variety of reasons; low on intercooler coolant causing cavitation and intercooler pump shutdown.
Higgs was trying to troubleshoot the issue to determine what the cause is since it is probably situation #2 a faulty component.
If your car overheats on the street in 1-2 pulls to 150MPH. Then you have a bad component.
I had an overheating issue on the track and the DIC said to stop and idle the engine. That makes more sense then shutting down assuming all systems are working. You got a different message so I suspect there is a specific fixable problem.
Lets not run around saying the sky is falling when cars overheat everyday for various fixable mechanical problems
If people have a problem they should define exactly what happened and under what conditions, what the instruments read (and any warning messages), how long it lasted and how bad the impact on performance was. If the gauges are set on the Tour Setting it only takes a second to glance across all the readings and see what they are.
Bill
