Official Z06 Problem List
#221
I picked up my zo7 yesterday. It took 20 to fix the Clutch nightmare. Runs strong at least for now.
Prior to GM replacing my engine 3 cylinders allowed a significant amount of oil to get into the combustion chamber. When I lost some power I always it was the ECM pulling timing. it was the ECM that pulled the timing. Now it appears that it was the oil getting into the combustion chamber. What more can go wrong with this Beast? My attorney still believes I will get all of my money back including the sales tax
#222
I might need to talk to your attorney. Warranty is bogus if they can't figure out how to fix the car in a timely manner.
forcewindu (07-01-2018)
#223
A/C Coldness at Idle
2019 Z06 Convertible A8, 3,030 Miles, Purchase Date 4/11/2018 - When idling, the A/C’s air temperature significantly increases even though the output volume remains the same. This started happening about a week ago. Driving the car (e.g. 30+ mph) results in an immediate drop in A/C air temperature.
#224
2015 ZO6 @ 8,000 miles the left rear mag shock started leaking the Dealership is squawking about replacing it under warranty. Even though it clearly has oil residue binding the road grime.
#225
The Consigliere
Received 5,447 Likes
I had a front mag shock replaced under warranty when it showed signs of leakage. My car was only about a year old, though. Don't know if the added time on yours is making them blink or not. But, I had no trouble on a warranty replacement of mine.
#226
2017 didn't change. Z06/M7/Z07 - A/C can hardly keep up with the Texas summer heat, and the seats are just a little better than nothing at all. I have the competition seats. Which by the way, the damn memory settings work about half the time. I figured out that if I move the seat just a little after I get in, then close the door and start they tend to work more often than not. If I don't move the seat before start up the memory never works and nothing moves - not the steering wheel, mirrors or the seat.
The following 2 users liked this post by westsideburns:
08redharley (07-12-2018),
froggy1140 (05-28-2021)
#227
seats
The following 2 users liked this post by Thomasmoto:
forcewindu (07-01-2018),
westsideburns (06-30-2018)
#228
I bought a 2016 Z06/07. I had decided to buy another brand. When I tried the ZO6 that was it. The car pulled like a bear. But I started to have some serious issues.
1. 5000 miles--Engine blew up. Dealer rebuilt it with help from GM
2. As soon as the temp went above 70 the ECM would pull timing. 80% of the time I never got the 650hp that I paid for.
3. 12,000 miles-Electronics crashed. Screen, navigator, radio all went dead. It took a month to get the replacement parts.
4. The car has always used a lot of oil. I am in the middle of consumption test run by the dealer. The car now averages 500-600 miles per qt. Dealer said they will either rebuild the engine or replace it. The oil is getting into the combustion chamber and it burns up. I assume this also hurts performance.
5. Since the hp was not anywhere near the 650 I decided to go to the 100 octane calibration. It works great with 100 Octane gas at $10 a gal. I tried Torco and Bustane. They both work but it is not as strong as with the 100 Octane.
6. The car is an M7. A couple of months ago I started having transmission issues. A number of times it either poped out of first or I didn't get into 1st properly. So I watched it carefully and it still popped out of 1st a couple of times. When I first got the car the transmission was fantastic. Now I have trouble getting the car into 1st or 2nd easily.
I have had enough.
I have had enough.
Anyway, my attorney has already filed the Lemon Law paperwork. He believes GM will return all of my money including the tax in about 50 days. I will believe when I see it.
The ZR1 is getting good press but I may be a little gun shy.
#229
Update:
Hello, apologies for the delayed response as I have been deployed...almost done...another two weeks! Anyway, wanted to give a quick update (timelines are general as I have forgotten the exact dates).
2016, Z06, A8
23 AUG 17: Car felt sluggish, dropped at dealership for repair.
25 AUG 17: Dealer says bad supercharger, ordered
15 SEP 17: Supercharger installed, not repaired. Seems there was a bearing failure which resulted in a spun cylinder. Parts order.
15 OCT 17: No update from dealer. Customer complains to GM.
15 NOV 17: Buy-back authorized.
1 DEC 17: 2019, Z06, A8 ordered.
2 DEC 17- 5 MAR 18: Waiting, waiting, waiting...Contacted by the repurchase department...paperwork generated, shipped to dealer
12 MAR 18: I go to do the paperwork, after securing a new loan...sign over my old car (that was eventually repaired, but I had to garage it til the new one arrived)
12 MAR 18: I am all excited waiting for brand new baby! Car is in detail...10 minutes, 20 minutes...then...Sir, there is a problem! I was floored!!!
12 MAR 18: Apparently, there was a computer problem and the screens didn't work. Repairs needed. Keep in mind I haven't even sat in the car...
19 MAR 18: Car not repaired, and I boarded a plane for an overseas trip.
1 APR 18: Car in for repair
1 MAY 18: Car in for repair
15 MAY 18: Contacted GM Customer service...again!
1 JUN 18: Buy back authorized
1 JUL 18: Second Z arrives, paperwork done. New car in garage.
7 JUL 18: Waiting til I can go home and enjoy it....I hope it works!
There are a lot of details I have left out. I will say one thing, the dealership was awesome throughout the whole experience. And I will keep it at that.
2016, Z06, A8
#230
St. Jude Donor '15-'16
2016, Z06, A8
2016, Z06, A8
#231
2016, Z06, A8
2016, Z06, A8
I just want to make sure I understand the sequence of events. When did you take delivery of the 1st ZO6? Then you write that on Aug 23 the car felt sluggish so you dropped it off at the Dealer. On Sept 15, 2017 a new Supercharger was installed but it did not fix the problem. In late 2017 the car was still not working properly so it went back to the dealer a few times for the same problem. Your timeline says you contacted GM. Did you tell them you've had enough and you wanted all of your money back or did they just offer to buy it back? Were you required to buy a new ZO6 as part of the buyback arrangement?
If you use the date that you dropped off the car because it was sluggish & nearly a yr passed before the buyback was approved? Wow!!
About a week ago My attorney filed under the Lemon Law statute. Even after 2 engine replacements, a score of electronic issues, missing HP, Clutch & flywheel replacements etc etc GM refused to do anything. This is the 1st Corvette I have ever owned. It leaves a bad taste in my mouth. I should have stayed with a Porsche gt3
#232
I just want to make sure I understand the sequence of events. When did you take delivery of the 1st ZO6? Purchased the 2016 Z06 in October of 2016. Then you write that on Aug 23 the car felt sluggish so you dropped it off at the Dealer. On Sept 15, 2017 a new Supercharger was installed but it did not fix the problem. In late 2017 the car was still not working properly so it went back to the dealer a few times for the same problem. Your timeline says you contacted GM. Did you tell them you've had enough and you wanted all of your money back or did they just offer to buy it back? I requested a replacement vehicle on both occasions. Were you required to buy a new ZO6 as part of the buyback arrangement? No, the first time, I requested a replacement. They obliged. The second time, I requested a replacement, but they actually gave me a straight repurchase. On JUL 1st, I basically sold back my replacement Z06 and purchased a new one (but I had them build an identically spec'd car, which was delivered to the dealer and they held it for me).
If you use the date that you dropped off the car because it was sluggish & nearly a yr passed before the buyback was approved? Wow!! The second complaint to GM was on the replacement vehicle. Effective, Gm viewed it as two separate transactions.
#233
Cold start tapping
2017, Z06/Z07, M7. 2705 miles. This week I noticed a pronounced tapping when the car is started for the first time after sitting overnight. The tapping seems to be at the rear of the motor and lasts about 15 seconds then gradually goes away. The noise is not heard again on any other start ups after that first initial start. Took it to the dealer on Thursday. They called yesterday to acknowledge they hear it too. It's sitting waiting on the "expert" motor guy to come in and diagnose this week. I don't think it's the fuel pump. Even after the tapping is gone, I still hear another rattle under the supercharger. That sound is more of a rattle. The noise in question is a a defined tap. Car has not been tracked, only street driven with some spirited acceleration after the break in procedure was followed exactly. Oil has been changed twice, once at 500 and again at about 1600 miles when I added the Chevy performance air breather kit. More to come.....
https://www.youtube.com/watch?v=EQyJ...ature=youtu.be
#234
7/10/18 - Dealer called today and said the motor expert "heard" the noise but would not be concerned with it. They "made a note of it" and will send the car home. "If there is an issue in the future" we will look at it again. Basically saying in so many words to drive it until it really breaks and hope at that point it's still under warranty. I don't know whether to be worried or relieved. I really wasn't looking forward to the dealer tearing the motor down, but then again, I'm not at all pleased with having the thing tick loudly for 20 seconds every cold start up. I'm really disappointed that I even have to worry about this from now on, as long as I own this car. It was supposed to be my dream car, once in a lifetime opportunity.
#235
The only problem i had was leaking windshield washer solvent tank. Turned out to be the pump and connector of the pump to the tank. Fixed with a 45 minute visit to elco Chevrolet. the other issue which I would say was a defect was purging and filling the intercooler tank. Once that was done the car makes back to back pulls with no loss in power.
Otherwise the car is pretty good. the performance isnt what I expected from 650 hp 650 ft lbs of torque. That’s a bit disappointing. But It is Better now with 1500 miles then it was.
#236
Cruising
2016 Convertible Z: Sometimes the memory seats work sometimes they don't. I'll go out and run errands and shut the car off, open the door and the easy exit works fine for a time or two. Go to the next stop and the easy exit feature doesn't work. Same when I go to start it up: sometimes the seat and steering wheel will move into correct position and sometimes they won't. Haven't had time to take it to the dealer.
Exactly the same. I have set, reset, tried different keys. Only had for 3 weeks so I will play with it some more before going back to my dealer. They only have one “Corvette Expert “there so I have to check which day to take it in.
#237
Cruising
How true. I am a 68 year old guy that traded a 911S for a 17 Z06 w/Z07 and M7 last month. Small town dealer had it on the floor for 2 years. What a beast. It is certainly an attention getter...and not always good. I can not put into words the feeling of running thru the gears and hearing that engine scream. Will do no mods or track days. Just enjoy while I can.
fargon (11-03-2018)
#238
Cold Startup Engine Tapping Noise
#239
Hood Color
It wouldn’t surprise me if your car has any of the “Clear Tint Tri-Coat” paint options (extra cost premium paint). Sounds like your hood was repainted at some point. They can never match the re-paint to the original factory paint job. I suffered some hail damage on a 2009 Crystal Red Tintcoat Coupe. It suffered minor hail damage to the hood, targa Top and hatch lid. Damaged areas were repainted 3 times, but they could never match the original paint on adjacent body panels. (Fenders & Front Fascia). Also, a friend of mine rececently had his 2017, Blade Silver, Grand Sport’s front fascia repainted 2 Times to correct paint chipping where the front fascia meets the fender in front of the headlight. (Common problem on the 2017’s). Still not a reasonable paint match. He gave up. Most body shops, including GM dealerships, will admit they can’t match it..... unless you do a complete repaint on the entire car.
#240
