flexible flap
Does anyone know what it is / what it's called?
What purpose it serves?
How much it costs to replace?
Should I replace?
Some people say it doesn't do anything but given how cost driven auto manufacturers are why would GM pay money to install something on a car if it wasn't needed to perform some desired function? I think GM knows more about car design than the vast majority of street corner kibitzers. I bet if you could dig through the design data for the C7 and C7Z06 that GM has reams of test data showing the exact affects of having or not having the air dams.
Bill
https://www.corvetteforum.com/forums...6-air-dam.html
I've also heard, like sTz says, that it doesn't belong on dry sump cars, but then why does the factory ship it installed on Stage 1 Zs? That'd mean dealer prep for EVERY Z would require removing it, since they all have dry sump.
So I'm confused as to what the right answer on Stage 1 Zs is...
There really has been no definitive explanation, aside from Tadge, who informed that at 150 mph the extra downforce provided by the center section caused a tendency to oversteer.
I also have something similar installed on my Chevy truck, an its purpose was described as improving fuel economy.
To the OP, you can repair it, replace it, or remove it... and I doubt that you'll ever notice any difference in aerodynamics, downward force, cooling, or fuel economy. If it were me, I would probably replace it... just because it was something on the car that was damaged, and really no other reason, however, many removed them... just because they drag on their driveway, or they appear unsightly...
Genuine GM I think.
I put some gorilla tape on the back for additional support.
Not sure if that's a good idea or not.
If it tears again I'll try something else.
