question on replacement warranty side skirts?
question for everyone is has any one had gm put side skirts on there car because of stone nicks on there car? Seems to me a car that ave cost is or above one hundred thousand dollars and known problems gm should install this at little to no charge. All comments are welcome-at 1900 miles i am seeing some nicks and believe me when i see a stone in the road i slow down and avoid it.
thanks for your advise
Mark
Mark
Received 1,767 Likes
Mark
Mark
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Using your same logic (from what I could decipher/translate), on a hundred thousand dollar car, spending $2000, or less, on side skirts is in fact "little to no charge." They make it an option for a reason, you could easily find out online that they make a difference or are recommended by most at this point. Why not add them to the car before you left the lot with it and rather expect the dealer/GM to give them to you for free?
Amat Victoria Curam
Replacement warranty skirts?
I am pretty confused by your words. The C7Z comes with 3/4 skirts standard. Do yours need replacement due to a manufacturing defect?
the 2016 did not come standard-gm knew about problems with the damage stone chips/nicks. When I bought this i was told get gm mudflaps which I had purchased and installed would take care of this-yes after reading many here I now know about side skirts keeping stones from hitting the rockers. just asking if anyone has made the case that gm should have installed these and since then gm installed them under a warranty claim after being confronted with a frustrated and pissed off customer.
