Caster setting
Old Jul 26, 2017 | 12:10 AM
c7jim's Avatar
c7jim
Default Caster setting
Hello I'm getting ready to do an alignment with my local alignment shop. The tech is suggesting a Plus .05 degrees caster. Setting in the rear. I've read it should be 0° straight up and down. Any thoughts out there
Old Jul 26, 2017 | 08:47 AM
Poor-sha's Avatar
Poor-sha
Track Rat
DSC recommends +.07 and that has worked well for me. Make sure the top of the shock is leaned back. See the alignment thread I posted in the tech section last night for some tips on setting this.
Old Jul 26, 2017 | 09:16 AM
The_Gretz's Avatar
The_Gretz
I had mine set at 0* and it made a huge difference in the stability of the car. I can't compare/contrast with +.07 or +.05, but glad to hear you are spending money where it counts. Many people don't seem to care about a proper alignment to include the rear caster.
Old Jul 26, 2017 | 10:22 AM
BEZ06's Avatar
BEZ06
The Chevy spec for rear caster is 0.0° +/- 0.8°.
I have the DSC mag shock controller, and my rear caster is set to +0.8°, which is still within the Chevy specs.
I think the DSC spec of +0.7° to +0.8° is a very good setting whether you have the DSC controller or not, and it's very good for the street and track.
To Caster setting
