NEW WEAPON-X Fuel Line Pump Kit w/ Return and Flex Sensor
Weapon-X Is Now Offering Our New Fuel Line Pump Kit With Return And Optional Flex Sensor.
High Flow Direct Injection for GM Generation V V8 Applications
These are designed for the new GM LT series engines. These supply the needed fuel flow for high horsepower applications and only come on when the more fuel is needed and are E85 compatible allowing higher output engines to take advantage of the octane of E85 fuel.
Features:
Features:
- Plug and Play Harness
- 375 LPH Fuel Pump
- Custom Mounting Bracket
- Custom Length Braided Lines
- Aeromotive AL fittings
- Aeromotive Fuel Pressure Regular with Return
- Billet tank fitting with feed, return
- In tank Pre-Filter
- Check Valve
- Flex Fuel Sensor (option)
See more here at: https://weaponxmotorsports.com/produ...ine-pump-kit-1
For questions or best pricing contact Eddie@weapon-x.com / 513-834-6818
Bump.
We're installing another one of our stage 3 kits right now, I should have some pics up by Monday. The pump alone in that kit will support 2000hp.
How is this tuned in? Boost referenced, Hobbs switch to maintain FP? Will the stock full pump maintain stock function with low and high flow referencing?
It is controlled by a boost referenced hobbs switch, then we set the FPR in the Line Pressure Kit to the same targeted fuel pressure as the FPDM so the factory pump and ours work in correlation together.
Just throwing this out there.
WzUpDoc (11-17-2017)
New pump options are now available.
SharkbyteLT4 (12-20-2017)
will this work with a DSX flex fuel kit already installed?
