Just putting up some pics of interest removed by photobucket.
4" I.D. flex tubing setup. Used the same piece of duct work from the gutter setup but now no extra room inside the duct work as you can see with the smaller flex tube gutter setup below. The screw clamp rounded the OEM duct work out.
Gutter Drain setup.
https://www.corvetteforum.com/forums...with-pics.html
I posted this up due to some interest from a forum member.
Gutter Drain setup.
When you go to post there is a icon along the top that is yellow and when you put your arrow on it, it saids: Insert Image. Then you can choose: Browse Your Device. It should go to your computer. Then select a picture and double click should do it. Finally click: Insert.
Another member filled me in on the icon and I figured the rest out.
SUBVETTE
When you go to post there is a icon along the top that is yellow and when you put your arrow on it, it saids: Insert Image. Then you can choose: Browse Your Device. It should go to your computer, Then select a picture and double click should do it. Then click: Insert.
Another member filled me in on where to go and I figured the rest out.
C7/Z06 Man (08-06-2017)
