Backfire
Old Aug 9, 2017 | 03:13 PM
767 cap's Avatar
767 cap
Default Backfire
My 2017 zo6 with 750 miles on it was running great until a few full throttle accelerations where it backfired when shifting (in automatic) . It accelerated well but the backfiringdurring the two shifts were a little disconcerting.
Has anyone had this issue before I take it back to Chevy?
Thanks in advance.
Old Aug 9, 2017 | 03:22 PM
Madsen's Avatar
Madsen
This will be instring to heart what some of the guys say.
I have my ideas but some of these guys been around engines more than me.
Old Aug 9, 2017 | 04:02 PM
jaden61's Avatar
jaden61
2017 C7 of the Year Finalist
Are you sure it was a backfire and just a relighting of the candles?
Old Aug 9, 2017 | 04:11 PM
ScGRaceR's Avatar
ScGRaceR
backfire? sounds or did you feel a loss of power?
Old Aug 9, 2017 | 04:16 PM
NmtMev's Avatar
NmtMev
A backfire is when the air/fuel mixture ignites in the intake tract before entering the cylinder. It is an explosion that travels up out of the heads, through the intake manifold and out the intake...
An Afterfire, sometimes called Afterburn, is an audible popping sound, individual or multiple that often occurs when the fuel/air mixture is too rich or has a momentary instance of a rich condition. This pop at times can and do resemble small caliber firearms going off. Afterfire occur in the exhaust and is heard out the tailpipes.
BACKFIRE IS BAD. AFTERFIRE IS OKAY!
Old Aug 9, 2017 | 04:17 PM
NmtMev's Avatar
NmtMev
So unless your hearing the sound from the front of the car....all is well...
Old Aug 9, 2017 | 04:31 PM
Warp Factor's Avatar
Warp Factor
Thanks in advance.
"Backfiring" during paddle-shifts, has been a source of pride for many BMW owners. Ya hear it quote regularly around Bellevue, Washington, and also around Redmond, Washington, a few miles away, the birthplace of Microsoft operating systems.
I grew up around that area, and I'm hard-pressed to find my way around any more. So much has changed, since big money took over the area.
I've never experienced my C7 ZO6 actually backfiring during a shift, but the throttle cut during shifting might loosely mimic it
Old Aug 9, 2017 | 10:53 PM
767 cap's Avatar
767 cap
Just sounds
Old Aug 10, 2017 | 10:30 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
It's not a back fire, it's fuel being cut off during a shift and then re-applied after the shift.
Old Aug 10, 2017 | 12:03 PM
djnice's Avatar
djnice
^^Yes and its normal. It makes a pop sound. This helps the A8 trans to shift faster.
Old Aug 10, 2017 | 08:56 PM
vettetwo's Avatar
vettetwo
All C7s do that. Even my lowly 2014 Stingray. It sounds really cool. The only thing that would make it cooler would be flames from the exhaust pipes as it shifted.
To Backfire
