How necessary is clear film?
Dave how about we call it a "bro" instead?
lol. I think you hit the nail on the head
you have lots of cars ones that fit that bill
most of us have one toy car which then becomes the be-all-end-all and a chip ruins our weekend LOL
When I "demoted" it to street use I picked up 300 miles and, as you can guess, a few stone chips....
I just took delivery of my new Z06 with the Z07 package. So far I love it. Only put about 50 miles on it so far.
I was fold these cars cars will sandblast the lower panels quickly due to the Cup 2 tires picking up every stone, etc.
i also plan on doing a couple of track days a year. Stone chips probably a certainty.
Thoughts? The film and ceramic coating is probably a $3500 ordeal. Not cheap.
Thanks in advance!!
Thanks in advance!!
The road course will sandblast your car and windshield from following cars prior to blowing past them, so if you value the appearance and don't want to respray the car prior to selling it, then get both areas protected.
I have Xpel Ultimate from the windshield forward as well as along the rocker panels and in front of and behind the rear wheels. Clearplex on the windshield although I'm going to try windshieldarmor.com the next time.
Bish
Bish
Received 8,928 Likes
Thanks in advance!!
Thanks in advance!!
The newer clear coat cars show it more since the clear coat is so hard the small sand particles coming out of the asphalt or just from what is lying on the road will slowly sand blast the sides. At first you won't notice the chips because they are so small but after a while there are so many of them the paint gets dull and certain waxes/polishes make them look worse.
People that say they don't have the problem don't drive the car enough or aren't looking at the correct area of the car. Look behind front wheel well, on rocker, lower door from the front part of the crease across the door diagonally up the door to about 5 inches below the door switch hole, rear quarters up to the point half way around the rear wheel well.
Front of car isn't a big deal unless you track it and run into rubber thrown off cars in front of you. On the streets very little gets thrown up by other cars and what does get thrown up will usually go through any film. I have the front fascia and the front of the fenders and hood done, mirrors, rockers and side skirts, rear quarters and lower door (should have done complete door).
Bill
