A/C is weak
Old Aug 20, 2017 | 04:20 PM
Chunu58's Avatar
Chunu58
Cruising
Default A/C is weak
Does anyone else have issues with their a/c not being very effective?
Is there a fix or should I learn to live with it?
Old Aug 20, 2017 | 09:59 PM
Doctor Mark's Avatar
Doctor Mark
I find that mine can not cool the car down after it sits in the sun. I do live in Ga and it is all black. No help from the dealer visit. This week will try to get the windows tinted. I hope that helps. Did not have this issue with prior black Corvettes.
Old Aug 20, 2017 | 10:24 PM
Higgs Boson's Avatar
Higgs Boson
i basically drive a different car every day and none of them have working AC's in July or August. probably a Y2K thing.
Old Aug 20, 2017 | 11:18 PM
Adam Silver05's Avatar
Adam Silver05
Sort of.....it is a non-r12 thing!
Old Aug 21, 2017 | 07:15 AM
hcvone's Avatar
hcvone
My new Vette does not cool like my escalade or hellcat, and the Vette stays much hotter for much longer than the other two, just lower with less grill opening, so on real hot days the Vette stays in the garage, my Vette has a transparent top so that does not help
Old Aug 21, 2017 | 07:21 AM
Wndotintman's Avatar
Wndotintman
The AC worked much better in my C6Z than my C7Z. One of the first things I noticed when getting the C7.
Old Aug 21, 2017 | 08:48 AM
Mr. Gizmo's Avatar
Mr. Gizmo
i noticed the same thing when I test drove a c7z earlier this summer. The c7z's ac didn't cool the car near as well as my c6z's ac.
Old Aug 21, 2017 | 08:53 AM
malexand123's Avatar
malexand123
Window tinting does help a good bit.
Of course, depending upon where you park, you can leave the windows cracked open an inch... this helps.
Given general A/C performance, I have 3 vehicles.
Dodge Ram Dually > Hellcat > Vette
Hellcat is better than the Vette it seems.... Hellcat whole front end is opened up for cooling. But reality is nothing cools better than my Dually. Of course it has radiator/condenser the size of Rhode Island.
Old Aug 21, 2017 | 11:11 AM
musclesbmf's Avatar
musclesbmf
I agree... It's the worst A/C of any car ever owned and much worse than any of the various C6's I've owned. The cooled seats are a joke as well.
The new Cadillac's do not have this issue with A/C or seats so I find it odd that the Corvette couldn't get it right.
Old Aug 21, 2017 | 11:30 AM
dar02081961's Avatar
dar02081961
If you go into the on screen settings you may find that the default max fan speed for the automatic A/C is set to medium. Set it to high, the car cools much better. ( I think this was done to keep the fan from being too noisy in the interior)
Also the A/C is taxed due to the heavy amount of heat transfer from the exhaust and engine to the floor. I have found if you set the A/C outlets to mix both the floor and the dash vents and manually run the A/C fan at a higher speed to compensate for the loss of flow to the dash, it helps in some cases. Plus when in this mode if you run the seat fans at high to grab the cool air you are sending to the floor and circulate it through the seat it helps tremendously. Much of the heat you are feeling is from your body and the leather seat itself, the seat fan helps with this.
However the seat fans are only fans. Therefore if you use them they are circulating whatever air they get from the cabin floor, so you have to keep this in mind.
If you don't send cool air down there you are sending hot air from the floor through your seat!
Old Aug 21, 2017 | 12:01 PM
dar02081961
The transparent top is more of a factor here than most think.
Even though its tinted it increases the heat load in the cabin a great bit on a sunny day.
Most folks comparing the Vettes A/C to other cars forget this factor.
For my C5 and C6 there was a inexpensive plastic/nylon mesh that you could purchase that adhered to the glass by static (no glue or residue). It just rolls on and peels off and you can still see through the top.
It cut down on the cabin temps noticeably. I haven't bought one for the C7 but I am sure they are out there.
Old Aug 21, 2017 | 12:30 PM
silver74vette's Avatar
silver74vette
The AC compressor on my 2017 Z is physically smaller than the compressor on the 2008 I was working on the other day. I agree the C7 seems to be weaker in the AC department, I will try dar's tips. My AC and vented seats struggle when it has been in the sun, but it is great coming out of the garage.
Old Aug 21, 2017 | 12:37 PM
hcvone's Avatar
hcvone
Got the plastic last week, TY. All my vette's have had the transparent tops.
Old Aug 21, 2017 | 01:01 PM
thorissr's Avatar
thorissr
I totally agree that the c7 isn't as good as the C6 AC. I live in Texas and some days it's just bearable when driving around with the AC maxed out on Low.
However I have noticed that my C7 Z51 cools much better than my Z06. So the car generating heat theory may have some weight.
Old Aug 21, 2017 | 01:10 PM
Oakmtnbody's Avatar
Oakmtnbody
Make sure you get the Ceramic window tint it's advertised as 10 degrees cooler.
Old Aug 21, 2017 | 02:25 PM
Batman 357's Avatar
Batman 357
My A/C is also poor. Three trips to the dealer with no improvement.
Old Aug 21, 2017 | 03:21 PM
ronsc1985's Avatar
ronsc1985
This might have something to do with the color of the car and the top type.
Mine is a 2017 white with a white top. It cools just fine even on high 90 days. So well in fact that my wife had her side set to 78 or so during our last trip in 90+ 76 dew point weather.
To A/C is weak
Old Aug 21, 2017 | 08:02 PM
gSwift's Avatar
gSwift
My white 2017 isn't very good and I have a white top. It's fine as long as I'm moving and have the rpm's up, but the second I stop or am moving slowly, it almost feels like the compressor kicks off. It feels like it gets real humid in the car
I've read a couple threads on this but it doesn't seem like anyone has found a solution for it. I'm sure GM will say that it's working as deigned. Meanwhile, my 16 Denali will blow snowballs at you non stop no matter if you're moving or not.
Old Aug 21, 2017 | 08:29 PM
ronsc1985's Avatar
ronsc1985
Comparing the cooling rate of a C7 to a 6 passenger SUV with less then a full compliment of occupants is foolish. The SUV has a cooling system designed to cool a much larger interior area with 6 passengers.
Would you expect a two bedroom apartment cooling system to have the same BTU extraction capability as a 7 room house?
Old Aug 21, 2017 | 08:50 PM
Batman 357's Avatar
Batman 357
No excuse for poor A/C during street driving. One more chance for the dealer then it's burn up the phone to GM.
