Alignment Question
Bill
Other than dealer what shops do you guys trust for alignment, firestone?
Is it true that for our staggered tires the original tire warranty of 30k miles will be halved, so only 15k cause we can't rotate it front to back.
It has a significant impact on the handling of the car and is a safety concern if not properly setup.
If you find a place that really knows what they’re doing you will not destroy your tyres in such short distances using the recommended GM or DSC settings.
Bish
A lot of dealer shops haven't invested in the tools required (they are not part of the alignment machine). They need an angle gauge and an adapter that fits on the inside of the knuckle (near the Rear Axle CV joint) to fasten the gauge to. Any shop that tells you they can set it using their alignment machine doesn't know what they are talking about. GM will loan them the tools but that may mean you would have to set the appointment around when they can get the tools.
Talk to the mechanic that will be doing the job. If you get a lot of humma, humma or promises they can do the adjustment without showing you the two tools required then they can't do it.
Tell them to look up the rear caster adjustment procedure in the Factory Service Manual. It is clearly delineated in the manual which most of them don't read. When you get the alignment sheets after they do the alignment the rear caster setting should be printed by hand on the sheet since the machine doesn't have the capability to measure or print the measurement.
Bill
Z got 2350 miles and have yet to get an alignment like everyone suggested, better do it quick!!
Got 2600 miles now the rears seem ok with much more tread life left but I just looked at them quickly, didn't have the car on the stands.
You need a new mechanic.
PLRX
also Thrust Angle: 0 degrees right?
rear toe were left 1/16" right 1/32", total 1/16".
Front camber were left -0.8, right -1.2.
Rear left -1.0, rear right -1.2.
Car seems to corner better, or maybe it's just a mental thing now that I got it done, need to drive it more.
Front caster were left 7.6 right 7.7, I told him to do 7.4 like Bill's specs but he did left 7.3 right 7.6 he said he took the middle number and it will drive better that way. By then I was beat and I didn't understand what he was saying, but it's a good shop so.
Front toe I wanted +0.01 and he did left 1/32 , right 0, total 1/32. Said that's the lowest they can adjust and also lowest of the "specifications".
https://i.imgur.com/NvbEGHG.jpg?1
Bill
thanks a lot Bill
I don't think I heard this before, car was always quiet not even 3k miles yet. Could it be that they forgot to tighten something or forgot something during the alignment? Or everyone have that noise.
A rare occurrence can be they left a tool somewhere in the suspension. Had that happen one time at a top of the line alignment shop in my home town. Did a great alignment but when I was out on the highway I started hearing a clinking sound. Stopped at a dealership on the way and the sound was definitely heard by everybody as I drove into the shop. There was a nice Snap On open end wrench inside the coil spring next to the shock.
Bill
