TracTive Shocks from DSC Sport - Pulled the Trigger
The DSC Sport controller was such a game changer I went ahead and pulled the trigger on a set of their TracTive shocks. Poor-Sha upgraded/traded-in to their top tier shock so I bought his from Mike/DSC. Installed last night. Review to follow.
PRETTY
PRETTY
w00tw00t (08-26-2017)
Like jewelry aren't they? Make sure when you install them that the connectors are firmly seated. I had one not connected properly when I installed the RTx shocks. Also don't forget to install the correct tune since the TracTive shocks work backwards from the stock shocks as far as current and response.
Finally, the rear shocks should come with a nut for the bottom bolt. The stock shocks have a nut integrated in to the bracket but the Tractive do not. Usually the nut is zip-tied to the hole when you get the Tractive shocks but I don't see it in your pic.
Enjoy them, I put my car anywhere on track I wanted to with those shocks and the controller.
Still dynamic and use the DSC suspension controller to dynamically adjust but the underlying technology is different. The Tractive shocks use a valve that dynamically adjusts rather than the fluid that changes with current like the MR shocks have. The issue with the MR shocks is that as the fluid heats up under heavy track use the damping changes. These are a proper race shock.
Lucky man...I was waiting to hear from Poor-sha to buy those from him.
The "hardest" part of the install was disconnecting the connectors without damaging as I didn't know how they released form themselves and their mount. After the first the rest were easy except they are in difficult places to access due to limited room and visibility. All except the left front.
I also ran into a problem as they didn't send me a nut for the rear shocks. I hit the OEM nut with my impact and it popped right off. I thought it was spot welded on but looks like it's just some high grade adhesive.
I installed Mike's TracTive file with no issues. Headed out to drive it in a little while.
Rick
Would love to get your thoughts and quick review. I'm waiting to pull the trigger on a set for myself. Would be particularly interested in learning how much they improve street performance and comfort over just the DSC controller.
Sean,
Rick
Rick
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I track my car and that is where the benefit really comes in but again, it is not a day an night difference. What you are gaining is consistency. As mentioned, the magnetic fluid heats up under prolonged use resulting in a less effective shock, the DSC shocks do not have this inherent issue.
Sean,
Rick
Rick
badhabit_wb (08-28-2017)
Former Vendor
I don't think buying the RT shocks for "street performance and comfort" would be a wise investment. I have the RT shocks on my car, and it does ride nice on the street, I'm sure Mike or Tom or anyone else from DSC would say the dampening on the street is measurably better but I can say, you are not likely to notice much of a difference. Or rather, you can play with the DSC controller and get 99% of what you want with the mag. shocks.
One of the other major limitations of the mag shocks that we don't often discuss is their limitation on shape of the damping curve, particularly on rebound. The mag shocks, due to relying on the viscosity of the oil, are limited to a symmetrical damping curve.
With the Tractive DDA, we can approach the "ideal" damping curve with incredible accuracy. In Figure 1, you can see an "ideal" damping curve. In figure 2, you can see the mag shocks overlayed on top of that for comparison - way off. In Figure 3, see the Tractive shocks overlayed on top of the ideal curve - extremely close.
Another downside of the OEM dampers is they are prone to magnetic hysteresis, which you can see in Figure 4.
Figure 5 demonstrates the effects of temperature on the magnetic ride shocks.
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
~Jordan
I can say one thing for sure. The tractive shocks and controller, along with alignment to your specs, transformed my car. It handles better, rides better, and hooks up better. As a percentage of the cost of the car it was a bargain. It took my car to a whole different level. I never expected the improvement in ride in combination with the improved handling. It's nice to feel the stability when I'm hard on the brakes going into a corner and I'm not worried about dragging the splitter on the track because it's diving.
Thanks for the data Mike - that is crazy to see quantified like that. The MR shocks lose nearly half their stiffness going from 0 to 80C!
DSC Tractive shocks
DSC TRACTIVE SHOCKS FOR SALE
I am selling these virtually new DSC Tractive shocks and controller I purchased these and had them installed before my last Chin day in May of this year... as others have mentioned on this thread… The performance is transformative for the car… If anyone would like to contact me to have a discussion about the performance I would be glad to share my experience. The reason I am selling these shocks is that I have Gone to the Darkside… I’ve purchased a Porsche GT3RS. Since the likelihood of the next owner of my C7 would not be tracking the car… I had the shocks taken off to sell out right… These shocks have 4-30 minute run sessions on them total! The controller has the latest software which is the programming for the ZR1 C7
Paid $6785 in May asking $5200 please contact me with questions or interest jthomas740@gmail.com
