Mobil1
Old Aug 29, 2017 | 10:12 PM
cdh027's Avatar
cdh027
Default Mobil1
Considering changing the trans and diff to Mobil1 at 500 miles. Do I need to add friction modifier to the Mobil1 75w90 for the rear diff? I know the GM stuff comes with it.
Old Aug 29, 2017 | 11:06 PM
pkincy's Avatar
pkincy
Its spec sheet has this as a feature: "Enhanced frictional properties"
Also nowhere does it say it is a Non Slip product. In Redline the 75-90 has friction modifier and the 75-90NS does not. Easy solution. Use it. Put the car back down and lightly turn in a circle. If it gives you a "gronch" sound it doesn't. Then put it back up and add a little friction modifier.
Also a google search for Mobil 1 75-90 gear lube friction modifier shows no results so it is not available separately. Other google searches show Jeep folks using it without modifier without a problem.
Old Aug 29, 2017 | 11:50 PM
AzDave47's Avatar
AzDave47
The GM products for tranny and dif are good products. Use them and don't worry about additives.
Old Aug 30, 2017 | 10:11 AM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
If you have a Z06 you have the E diff & do not need to use friction modifier.
Old Aug 30, 2017 | 10:20 AM
cdh027's Avatar
cdh027
Thanks!
Old Aug 30, 2017 | 11:20 AM
-HAIRBALL-'s Avatar
-HAIRBALL-
The owners manual calls for DEXRON LS (limited slip) gear oil. I put this in mine...
Old Aug 30, 2017 | 07:45 PM
stevebz06's Avatar
stevebz06
I had a tech rep from Standard Gears, who make their living rebuilding transmissions and differentials, tell me that you should never use anything but the factory prescribed lube in the GM differentials. This was after another one of their sales reps convinced me to use something else in one of their very expensive special remanufactured differentials and it was toast in less than 700 miles.
To Mobil1
