P16F3 Code Control Module Redundant Memory Performance
Read the code once I got to work and then tried to clear. I couldn't get the code to clear.
Resigned myself to making a trip to the dealer, however after the return trip home and two more engine starts (a total of 4 since the code set) and the light has gone out.
More research to follow.......
It is only just back from the dealer a week ago for the P050D code that resulted in an injector replacement.
The car has been perfect up to this point, so I guess it's just a bit of bad luck coming back to back.
The ECM detects an internal failure or incomplete programming for more than 10 s.
Circuit/System Verification
1. Ignition ON, clear the DTC information with a scan tool.
2. Verify no other DTCs are set.
⇒ If any other DTCs are set
Refer to Diagnostic Trouble Code (DTC) List - Vehicle for further diagnosis.
⇓ If no other DTCs are set
3. Verify DTC P0602 or P0630 is not set.
⇒ If any of the DTCs are set
3.1. Program the K20 Engine Control Module. Refer to Control Module References.
3.2. Verify DTC P0602 or P0630 is not set.
⇒ If any of the DTCs are set, replace the K20 Engine Control Module.
⇓ If none of the DTCs are set
3.3. All OK.
4. Verify DTC P0601, P0603, P0604, P0606, P062B, P062F, P16F3, or P262B is not set.
Replace the K20 Engine Control Module.
5. All OK.
