Getting my Z06 to 1000 hp !
#61
I have a stock Z06 without any modifications, so not speaking from experience. But I do not see how bolt ons, with cams and some port work will add 350 hp. The biggest restriction is the factory supercharger and you haven't done anything there. I would think this combo would add about 100-150 hp.
#62
Big question or issue is no Meth and stock injectors. I am not convinced you need new injectors for 750 whp but Meth maybe needed.
#64
That shop Sonic MS doesn't even specialize in GM cars why are you going there? They work on German cars mostly (bmw,AMG, etc). You need to go to Synergy Motorsports and talk to Rick in Livermore or Matt with GP Tuning. These guys build high power GM cars all day long and have built plenty of C7Z cars.
Harbgrogan (08-28-2020)
#65
#66
Injectors would be easier, ran a meth kit on another car (not a C7) and it is a huge PITA. Your tuner should prefer getting fuel in the proper way over a 9th nozzle with a pump, tank and all kinds of other variables to put in play. Plus, constantly refilling and buying methanol is annoying. On a car like this I'm not sure why you wouldn't prefer a slick solution. This isn't a JDM ricebox.
chevyfanatic (09-22-2017)
#67
here is a build almost like mine but running a more aggressive Cam on stock Blower and 802 whp
#68
Ultimately outright dyno numbers are silly, it's a tool used for tuning with outdoing dangerous street pulls to simulate lots of conditions and to give some idea about baseline vs. modified numbers. There are so many variables you can adjust to cheat the numbers up, I know as I have seen it done many times.
#69
But anyway, he has a pulley which is adding 4-5 psi of boost. That is a big difference on power with those other mods. I'm not sure why your shop did not recommend that.
Remember we are only at 530 whp stock so this car is going to be very fast compared to 99.99% of cars on the road. 9 secs for sure on DR
#70
I have a lower pulley to but he said dont use the upper pulley ! if I get to 750 whp I will be super happy ! Plus tuning the TCM will help too and make the car more responsive.
chevyfanatic (11-21-2017)
#71
#72
Jeff,
Here's the time line:
Halltech Cold Air Intake - Freshly restocked if ordered today will ship out tomorrow (4 days)
ATI Harmonic Damper w/ 10% OD Pulley - Needs to be built/packed up (1-2 days) Shipping from east coast Baltimore (5 days)
Fasterproms Expansion Tank - Backordered (2-3weeks)
C&R Heat Exchanger - Backordered (2-3weeks)
American Racing Header w/ High Flow Cats - (~1 week from order date)
Texas Speed Camshaft Package - If in stock (3/4 days) If not in stock (about 1 week)
Texas Speed DOD Delete Kit - (3/4days)
#73
18% lower
LME ported heads
LMR custom cam w 32% lobe
DODdelete
100% alkycontrol
50% E85
halltech C.F. CAI
LMR expansion tank
LMR heat exchanger
LMR 170* thermostat
LMR low side fuel system
MT at streets
9.97 @ 146 in 98* weather
going to switch to primarily 1/2 mile and mile events after the procharger 1000+ at the wheels
#74
ARH 2" headers
18% lower
LME ported heads
DODdelete
100% alkycontrol
50% E85
halltech C.F. CAI
LMR expansion tank
LMR heat exchanger
LMR 170* thermostat
MT at streets
18% lower
LME ported heads
DODdelete
100% alkycontrol
50% E85
halltech C.F. CAI
LMR expansion tank
LMR heat exchanger
LMR 170* thermostat
MT at streets
#75
No. Based on MPH in the 1/4 mile, power is right on. Making the switch to limit breakage until we have upgrades available for the diff and trans. I stopped paying attention to dyno sheets and try to spend time performance testing.
#76
I'm not a builder only a customer with what I've seen, purchased, and discussed with the experts it's unlikely to reach 700 whp.
Suggestions people have made are spot on and excellent choices
Enjoy and have fun with whatever you choose!
Fred
#78
JMHO: The build you are proposing unlikely reach into the 700's who. Set expectations correctly with 640-660whp and be surprised anything else above. Total flywheel HP I'd put a guess in at 775-800HP. the quote you posted is VERY similar to my build less the heat exchanger (SAME COST AS MY METH KIT) and 4k higher cost. something to consider is price out the job once you know what you need.
Fred
Fred
other builds like this are over 700 whp. did you actually look at the MODS ?? headers/cam/E85/ported heads ! lol
#79
That build will not come close to 1000 HP. You'll get maybe 20-30 hp more than I suggested to set goals for.
Go for it and get a good dyno readings and let us know what reality is. The guy with the Procharger F1 without a second thought has a killer setup that is a 1k+ HP build.
Also these C7 Z06's are heat monsters. Meth is supplement fuel, but more used to drop intake temps to advance timing and yield more power a the same temps before you overdrove the SC. When overdriving the SC keeping the temps down is a must. For me every LT4 engine could use the dropped temps (40-50 degrees). If you're going to drag at the track it really helps keep the temps down and yes provide a little more power by adding maybe 4 degrees of timing to your tune.
Best
Fred
