Flashing engine light
Old Oct 21, 2017 | 09:48 PM
Chunu58's Avatar
Chunu58
Cruising
Default Flashing engine light
While driving around town today making a few stops along the way, my check engine light began flashing. I do accelerate somewhat aggressively, but not that badly.
The temperature was at 200 like about normal in city driving.
When I slowed down on my way home, the light went off.
Any ideas why it was flashing or if I have a problem. (2015 Z06 m7).
Popular Reply
Oct 22, 2017, 12:04 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Originally Posted by Classic-Chevy-Guy
Did u check that the gas cap was tight. Common cause and takes awhile after tightening to clear the code.
Originally Posted by feeder82
a loose gas cap will not cause a flashing cel, just a steady light.
This actually made me LOL. The C7 does not have a gas cap guys.. you know better lol. Its a capless system!
Old Oct 21, 2017 | 11:02 PM
madrob2020's Avatar
madrob2020
OM says flashing CEL is a malfunction has occurred & emission control system could be damaged. Reduce speed & avoid hard acceleration & uphill grades. If light continues to flash, park, turn off vehicle,wait at least 10 secs. & restart engine. If continues to flash, see dealer ASAP. You should go to dealer to have them do a CEL malfunction scan to see if a code was thrown which would identify what happened. (Me, a '16 M7Z).
Old Oct 21, 2017 | 11:20 PM
geterdone's Avatar
geterdone
200 what more exactly oil, iat, coolant?
Old Oct 22, 2017 | 07:21 AM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Old Oct 22, 2017 | 09:08 AM
AWARE02's Avatar
AWARE02
St. Jude Donor '15
I have been having the same problem, dealer has replaced about every module in the car and has GM tech center involved to no avail. They recommend not to drive it, so my car has been at the dealership. Hope you have better luck and OBTW our cars do not have gas caps.
Old Oct 22, 2017 | 10:10 AM
feeder82's Avatar
feeder82
Old Oct 22, 2017 | 10:31 AM
Chunu58's Avatar
Chunu58
Cruising
Oil
Old Oct 22, 2017 | 10:47 AM
NSC5's Avatar
NSC5
A flashing CEL usually means you have a persistent misfire on one or more cylinders. Bad fuel can cause this issue but more likely it is a plug, plug wire, or coil pack problem although an injector can also cause this misfire condition.
Get it to the dealer so they can pull the stored codes. It should indicate misfire or one or more cylinders and they can take it from there.
A flashing CEL isn't used as an indicator for low oil pressure, high oil temperature, or high engine coolant temperature and these have their own warning lights and/or DIC messages. The flashing CEL is used to get driver attention and indicate an important engine code because a misfire due to lack of spark will result in dumping raw fuel into the exhaust with the potential of overheating the cats and creating a fire.
Old Oct 22, 2017 | 11:52 AM
Thomasmoto's Avatar
Thomasmoto
Hit the Onstar button and let them run a diagnostic. Let us know what they say.
Old Oct 22, 2017 | 12:04 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Old Oct 22, 2017 | 01:17 PM
Classic-Chevy-Guy
You’re so right. Brain fart on my part.
Old Oct 22, 2017 | 02:31 PM
lt1z's Avatar
lt1z
Flashing CEL means a current misfire. You will want to narrow it down to specific cylinder(s) and go from there. If the car is stock take it to the dealer. If it is modded work with a performance shop to figure it out. It sounds like it is an issue only at higher rpm so you may want to check out the plugs and wires.
Old Oct 22, 2017 | 02:36 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Take it to advance auto. They can pull the code (they wont clear it thpugh) and we can tell you more with the code once you have it..
Old Oct 22, 2017 | 09:34 PM
Chunu58's Avatar
Chunu58
Cruising
I took it for a brief spin today. Now I get a service rear axle notification in addition to the flashing check engine light. I already have made an appointment at my local dealer.
Old Oct 22, 2017 | 10:05 PM
NSC5's Avatar
NSC5
You will get rear axle and usually stabilitrack warnings when there is an engine power delivery issue because these systems cannot work properly when the engine isn't operating as designed. Once the CEL/misfire issue is resolved the other problem(s) will likely also go away.
Old Oct 23, 2017 | 06:49 AM
AWARE02's Avatar
AWARE02
St. Jude Donor '15
See post #5, I am having the exact same issues!!! Hope you have better luck than I have!!
Old Oct 30, 2017 | 09:41 PM
Chunu58's Avatar
Chunu58
Cruising
Good news:
I had my 15 m7 towed to a local dealership today. They replaced a faulty ignition coil that has seemed to cure all of the problems so far. At least there was no problem on the 15 mile ride home.
To Flashing engine light
Old Oct 31, 2017 | 01:11 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Good deal!
Old Mar 17, 2023 | 03:24 PM
murrayphoto819's Avatar
murrayphoto819
there is no gas cap on a C7 Corvette
Old Mar 19, 2023 | 12:34 PM
LiManZ06's Avatar
LiManZ06
Thank you for resurrecting a 6 year old thread to point that out. LOL
