Jacking the C7
Old Nov 4, 2017 | 11:29 PM
Track's Avatar
Track
Default Jacking the C7
Love my new Z06, and I see in the owner’s manual where the jack points are on the frame. But, like, how do you get a jack under the ground effects skirts??
Old Nov 4, 2017 | 11:46 PM
badhabit_wb's Avatar
badhabit_wb
Really low jack and jacking pucks. I use the red pucks from Katech and an AC jack. Works like a charm.
Old Nov 5, 2017 | 09:47 AM
Track's Avatar
Track
Thanks! Hate to have another jack lying around...but I guess I have no choice.
Old Nov 5, 2017 | 09:50 AM
ferraf's Avatar
ferraf
I have a set of ramps I use for the front to get my low profile jack in place.
Old Nov 5, 2017 | 09:57 AM
badhabit_wb
That works too. Especially if you want to use the center jacking point to raise the front end. I also bought cross beam adapters off ebay to help when I did that.
Old Nov 5, 2017 | 11:14 AM
Mad Dog 24's Avatar
Mad Dog 24
From: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
I change tires at the track sometimes and found with a jack puck (aluminum) and very low profile jack I can lift the complete side of the car using only the rear most mount. It sure save time moving around everything. BTW my car is lowered about and inch from stock.
I bought 4 pucks years ago and what a waste I only carrier 2 with me now to the track. PM me and make me an offer on the other two I will UPS them to you. Jeff
Old Nov 5, 2017 | 11:16 AM
Track's Avatar
Track
The pucks are new to me. It looks like they key into slots in the frame...making a more solid lift point?
Old Nov 5, 2017 | 12:03 PM
VictorBarron's Avatar
VictorBarron
Yes they do and they are a must have to keep in the car.
Old Nov 5, 2017 | 02:53 PM
Mad Dog 24's Avatar
Mad Dog 24
Yes they do that and keep the jack from damaging the rockers and other parts and pieces underneath your car. They fit very snug, we had to grind a bit off our to get them to turn to lock properly. Not a bad idea to keep one or two in the car for that unknown situation.
Old Nov 6, 2017 | 09:43 AM
hebegb's Avatar
hebegb
I drive my car onto a 16 inch long piece of 2x8 per wheel. Works perfectly without the need for a low profile jack to lift her up.
Old Nov 6, 2017 | 11:28 AM
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
Some photos here: http://www.burgertuning.com/corvette...d_adapter.html
Old Nov 6, 2017 | 03:34 PM
rikhek's Avatar
rikhek
I'm a tight *** and never understood the whole jacking puck thing. I've used the same 4" long scrap piece of 2x4 on my last 4 vettes. That and a Harbor Freight $80 jack and you're good to go.
https://4.bp.blogspot.com/-V69ddUpmT...4%2Bcrafts.jpg
https://shop.harborfreight.com/media...mage_25551.jpg
Old Nov 6, 2017 | 03:45 PM
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
Wood works fine, as do hokey pucks, but the the jack pad locked in its a bit more secure and safer IMHO.
Old Nov 6, 2017 | 10:45 PM
Track's Avatar
Track
Great. Thanks to all for the explanation. Now I’ve got an idea of what I need to order!
Old Nov 7, 2017 | 12:30 PM
jaden61's Avatar
jaden61
2017 C7 of the Year Finalist
I drive onto a 2x6, my old jack slides under then.
To Jacking the C7
