2017 C7 Z06 Warranty Alignment Paint protection Questions
Not new to corvettes, but new to C7Z so have some newbie questions.
Tires: For those who do not track your car, did you get a wheel alignment at the 500 miles oil change? Since it will not be used on the track, the wheel alignment will extend the tire tread wear helping the tires to last longer - is this a common practice with non tracked Z06 and Grand Sports?
Paint protection: I've seen most of the threads on the mud flaps and will need to get those. It looks like there is already protection at the rear air duct - similar to cleartastic - must have been installed from the factory? It does not come to the edges though like I read cleartastic does - not sure if it can be changed out though. Was this something offered on the 2017 models that was not on the 2015-2016?
Yes get the alignment done at 500 miles for sure if you are not tracking, I did mine then and at 3k my tires have perfectly even wear across. I did my 17 z the same way and at 5k miles had the same great wear on all tires.
I would strongly recommend doing clear bra on the entire rear quarter and adding guards of some kind. The clear piece was the same on all years from OEM. Enjoy!
Gonzo (12-07-2017)
Gonzo (12-07-2017)
Received 8,928 Likes
The factory alignment is more of a performance street alignment Vs a track alignment. The factory alignment comes with front and rear camber around -1.1 degrees while the recommended track alignment is -2.0 degrees. You can change the camber to -0.7 or so and get better tread wear without sacrificing street handling. Increase the camber more than -0.7 and you will start to lose the feel that makes the car a Corvette.
Bill
Bill
Gonzo (12-07-2017)
Received 1,767 Likes
Yea at 500 miles I told them to check the alignment, and wanted it for the street, which it comes from the factory that way, but mine was slightly off. Paint protection I put on the factory mud flaps aka factory splash guards, and had the whole car wrapped in 3M clear protection, 100% of the painted surfaces, after I did paint correction.
Gonzo (12-07-2017)
I believe it's hit or miss with a "good" factory street alignment. I kept close eye on all 4 tires from purchase in Aug. '16 ("16 m7 Z), especially when jacking to add mid-pipe, brake pad changes, skip shift eliminator, & just as a matter of getting down on knees every so often. Now at 9000 miles with no uneven wear. Did do the left to right rotation at 7500 miles. I've been to Spring Mtn. but honestly on county/state roads how would one know if the car is handling better or worse with an alignment? Sure, on a prepped, smooth track like SM (they use sweepers each nite to get rid of gravel) you probably would notice but roads are way too uneven, different types of surface material (sometimes within just a couple of miles), "ruts", harsh bumps, etc., to "know" it has improved after alignment. Just keep checking treadwear about every 1000 miles & as soon as uneven wear shows (if), like others have said get it done before the required period expires. JMHO
Gonzo (12-07-2017)
Can't speak for paint issue as I don't have any but when I went in for the "under warranty alignment" it has to be under 6 months of ownership and under 7500 miles. I recommend doing it right away if they have all the proper tools. They did give me a price break of $129 as I was beyond 6 months, still not expensive.
If your under 6 months and your at the 500 mile oil change, just tell them your car is pulling some and to do the alignment (if they have the proper tools). It should be covered under warranty. If outside the 6 months and miles, my dealer quoted me by the hour. 2+ hours roughly is the norm, so about $250. $500 seems very high. My dealer gave me a break at the passenger car rate of $129, but they should be quoting by the hour.
They seemed surprised I refused it.
One of the largest Vette dealers around.
