Halltech Stinger-CFV Helps Jason's C7 Z07 achieve 860 HP!
Supporting Vendor
St. Jude Donor '09
860 HP anyone?
http://www.halltechsystems.com/Hallt...V-p/hstcfv.htm
Halltech's C7 Stinger-CFV (Carbon Fiber). Use coupon code CFV15 at checkout. We have one in stock, with more coming in December. This is your one and only chance to own one of our Limited Edition Carbon Fiber induction systems.
Our Stinger in Carbon Fiber got the thumbs up from GM after extensive testing at the Milford Proving Grounds. Their Specialty Vehicle Program wanted to carry this system, but we did not have the capacity to make as many as they forecasted.
Fits 2015 through 2017 C7 Z06
100% Carbon Fiber. No fiberglass fill.
As seen in this article: http://www.corvette-mag.com/issues/1...chnology-creep
First Dyno ever done on our system in February 2015
Second dyno done; both without touching the ECM i.e no tuning.
Complementing engine components include GM high-speed lifters, PAC valve springs, Katech titanium valve-spring retainers (on the intake side), a C5-R timing chain, a ported supercharger and supercharger snout, a 103mm throttle body, ARP head studs and American Racing 2-inch headers. The engine draws its breath through a Halltech Stinger RZ carbon-fiber air intake, while Katech’s signature cast-aluminum valve covers and relocated coils deliver visual distinction under the hood.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
262-510-7600
For service email:
Just an FYI. If you couple this intake with Katech’s CF radiator exit duct, there’s no closing the hood as neither piece has any give to it. Had to remove the thick bulb seal from the exit duct & replace with a flatter seal that had more give to it.
Supporting Vendor
St. Jude Donor '09
One down, one to go. Customer #1; I had the wrong coupon code. That has been corrected.
Any orders over 2 will be shipped one to two per week.
We are finishing a 2nd mold next week.
Supporting Vendor
St. Jude Donor '09
All gone
The two we had in stock have been purchased. If you want to order at the reduced pricing, we have changed the pricing to a deposit $500.00
We will ship in the order sequence we received.
