Broke my rear diffuser - help
Old Nov 27, 2017 | 02:59 PM
mike123460's Avatar
mike123460
Default Broke my rear diffuser - help
Hey guys, I'm currently around 650whp, 700 tq. Been to the track several times before and no issues. Tuner decides to change a few things and then the next day first pass I break my rear differential on the launch but run a new PR for myself @ 10.3 at 137 LOL, no idea how. On MT ET S/S DR.
Anyways, I was lucky enough to get it replaced under warranty. I want to go back eventually. How do I make sure this doesn't happen again? Could it have been me and the burnout wasn't long enough? Maybe I missed the water spot when I reversed back (not 100% sure if I was in it or not).
When I was at the dealer, he told me there were several other vettes in for a rear differential as well. Curious to see if this is a common issue or not.
Old Nov 27, 2017 | 04:58 PM
HorsePowerObsessed's Avatar
HorsePowerObsessed
I'm confused. Was it your diffuser or differential?
Old Nov 27, 2017 | 07:45 PM
383vett's Avatar
383vett
Must be differential. Op has a really nice dealer.
Old Nov 27, 2017 | 07:48 PM
HorsePowerObsessed
Yeah if it's the differential then he DEFINITELY has a nice dealer. Hell either way it's pretty nice lol
Old Nov 28, 2017 | 09:12 AM
mike123460's Avatar
mike123460
Differential** Sorry haha. Yeah, luckily the performance shop I work with have some connections with the dealer. It was a 6000$ job.
Old Dec 5, 2017 | 12:28 AM
Roosters's Avatar
Roosters
Default My differential broke too
+1
My Z06 has been at the dealer for almost a month waiting for parts to fix my broken differential. Unlike the OP, though, my Z is bone stock.
It's a 2017, A8, Z07 with under 7500 miles. The rear end just started whining and quickly got louder and louder...I took it in and they said it needed a new diff. I'm hoping to get it back this week.
Eric
Old Dec 5, 2017 | 01:50 PM
mike123460's Avatar
mike123460
Weird. Mine broke with a launch. Wondering at what power levels an aftermarket differential is needed.
Old Dec 5, 2017 | 08:30 PM
lordofwar's Avatar
lordofwar
Originally Posted by Roosters
+1
Eric
my rear end was replaced at 500 miles.defect from factory,2016.alot of bad ones out there.
Old Dec 6, 2017 | 09:59 AM
mike123460's Avatar
mike123460
How did you know yours was defect?
Old Dec 6, 2017 | 10:40 AM
MIGHTYM0USE's Avatar
MIGHTYM0USE
it is not in the amount of torque but how it is applied, and if you are hooking or wheel hopping.
there are only two spider gears vs the 4 it would take to really be durable for the weight of the c7
if its not going to be the diff then it will be the axles, or both eventually.
Old Dec 10, 2017 | 08:59 AM
Jaycajun's Avatar
Jaycajun
I saw a Z at the track break the dif launching on 18" DOT slicks. Was cutting 1.30 60' times...
Old Dec 10, 2017 | 11:46 PM
BadC7's Avatar
BadC7
Mine broke the same way. I was trying to do a burn out. I have similar stats as far as hp and tq. But my 60 ft was 1.41 and I only trapped 130. I am also getting mine fixed under warranty. I am going to not go to the track until after I get an RPM differential with wavetrac.
Old Dec 11, 2017 | 05:50 AM
Warp Factor's Avatar
Warp Factor
Autos or manuals, or some of each?
Old Dec 11, 2017 | 10:34 AM
mike123460's Avatar
mike123460
Mines auto
Old Dec 11, 2017 | 03:23 PM
Roosters's Avatar
Roosters
Mine is auto too
Old Dec 12, 2017 | 08:32 AM
BadC7's Avatar
BadC7
I have an A8.
To Broke my rear diffuser - help
