Aftermarket front bumper track splitter for C7 Grand Sport
Hey Guys I just bought a front crashed c7 gs, looking to make it a dedicated track car. I have looked for decent aftermarket front bumpers and splitters but I have had no luck on the bumper. Anyone can make any recomendations?
Here is a pic of the car
Its a 2018 GS Carbon 65 car number 22
What's the story with this one? And why not restore it with factory parts?
Not sure, I bought it at an auction, I could fix it with factory parts however since I have to redo the whole front I wanted to put a more aggressive and stronger front splitter and bumper to hold directly at the frame. And maybe save a little money. If you know of a place I could find cheaper factory bumper please share.
With it looking like you need a bumper, hood and fenders I would consider replacing the front end with ZR1 parts for better cooling and Aero. Only thing is that those parts are not out yet and I expect they will be $$$.
I believe the front bumper is the same on all current C7 models. (just not ZR1) So any C7 bumper should work. Same with the hood between GS and Z51/Stingray. Splitter there are a ton of aftermarket ones. I believe the fenders are specific to GS/Z06.
You might double check the part numbers between GS and Z06. Since the hoods are different the bumpers might be slightly different. I can't tell from my photos of each (I have had both). Hopefully someone will post an aftermarket option for you.
yes that is something else I have been trying to figure out, are the C7 Stingray bumpers the same as the Z06 and GS?
I am pretty sure the stingray bumper is different where it lines up to the fenders because the stingray fenders are narrower. When they made the Z and GS they didn't only add the black plastic on the fenders the fenders are actually wider and flared more.
I just noticed your fender is missing the black plastic that wraps around it. I suppose it was tore off with the bumper.
c4t (12-11-2017)
This site says the front bumper is the same part no. I am not sure I believe it, but I suppose is possible.
https://www.cultragfactoryparts.com/...nts-front-scat
If anyone has done this before please speak up.
thanks!
Front bumper is the exact same part across all C7s except the new ZR one.
Yea I need to change a fender, if they were available I would probably do the swap for it all.
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
C4T, Dedicated track car sounds like a fun build. I built a few .... well many wrecks for street and track. I would first get the car on a bench and have the chassis laser measured with equipment such as Chief LaserLock for safety and alignment purpose. You want to confirm there is or is not any structural damage. I would be surprised if there is not as the frame horn ends are way out front on these cars. After get an alignment or try before you go to far. A twisted rail or unseen buckle after its all done sucks.
Lucky you don't have to worry about cooling to much with the NA. These cars can run wide open all day long from the few i have seen at the track. I would go with basically a stock front for now as the parts are not to costly. These cars have great balance in stock spoiler form. Keep in touch we all like to see the progress. Good luck...... i hope you are a collision technician or have a friend, that sure will save some big labor dollars
PS. put a cage in it, safety first!
I will have it laser checked and alligned like you said first hopefully its not too bad.
Have you used any cage on C7 that you would recommend?
Thanks I appreciate any and all advise I can get, a shop a friend of mine has used before is doing the rebuild work therefore I doubt I would save much $ there.
