Gearing
gear
When I had my 2015 I seriously considered it. Had I not sold it and ordered my 2016 A8 I would have. That M7 is really a close ration 4 speed with 3 overdrive gears in it. I think if you put some 4.56 or 4.11's it would really wake it up, but prolly stil.l be hard to launch with much power.
Received 2,379 Likes
I don't think there is gearing available yet so no use considering it.
https://www.motivegear.com/auto-part...model=corvette
I called Motive right now and they said it is just a number in the system, part doesn't exist and nothing shows on order to bring them into existence.
There is nothing to consider as they aren't available. A couple companies have been trying to work things out a few years with no luck.
[QUOTE=saleen556;1597227571]
I believe it has to do with the size/space in the Differential. Just not enough room. I highly doubt they come up with anything.[/QUOTE
well ladies you are kinda right. you CAN change the gearing just have to do so in the tranny. if you put a z51 tranny or send the z06 tranny to rpm you can change the first three gear sets. and yes it makes all the difference in the world.
Received 1,817 Likes
Probably not much of a market for it, since one can just buy the A8 instead.
