Build your own engine
Old Dec 29, 2017 | 08:35 AM
BDASSZO6's Avatar
BDASSZO6
Default Build your own engine
I have a 2019 ZO6 on order and would love to be part of this special program. Can someone give me the specific info regarding how to go about this? It would be greatly appreciated. Thanks!
Old Dec 29, 2017 | 09:50 AM
madrob2020's Avatar
madrob2020
I believe you can go to the BG website to locate this info or # to call to get precise instructions on how to set it up. Also look up corvettemuseum.org for some info. You might have needed to set this up at time of order & it appears there is a steep charge for this.
Old Dec 29, 2017 | 10:00 AM
Thomasmoto's Avatar
Thomasmoto
It's also an option listed on the order sheet that the dealer submits for your order.
Old Dec 29, 2017 | 10:09 AM
flying_vette's Avatar
flying_vette
It’s a 5k option you need to add at ordering time. Read more here
Old Dec 29, 2017 | 07:52 PM
GMHZ06's Avatar
GMHZ06
There have been a number of threads posted about it, so I suggest searching. M.J.Dart did the best write up, most detailed, with some pictures of what you receive. I did it on my 2017 and highly recommend.
Old Dec 29, 2017 | 08:57 PM
breakskeet's Avatar
breakskeet
It was an awesome experience. The engine build experience has to be selected as an option at the time the order is placed. Once your event code is 2500 or higher I believe the order can not be modified. Check with you dealer.
To Build your own engine
