Brake System Failure
I bought my Z06 brand new last March. My Z06 currently has 4300 miles on it. I have never tracked this car and was actually complimented that I average 26.4 MPG. I have been very sick the last several months and haven't had a chance to fully enjoy it yet.
I took my car into a GM dealership this weekend to have the brake pads replaced to reduce dust and to replace my tires with DWS. While replacing my brakes and tires the service department had to keep my car longer because the electronic brake bleeding mechanism wasn't working.
Yesterday, 15 JAN 2018, I picked up my car and within a few miles my electronic brake system failed. I lost power steering and a bunch of errors popped up. Rear stabilizer, rear axle, brake, ABS errors etc.
I took it back to GM and the head corvette mechanic ran a diagnostic. He came back with several errors. He was able to clear some of them but others remained. From what he told me, there have been long standing error codes. I left the car there.
Is something like this covered under warranty?
Also of note, when they were changing out my tires the mechanic noticed one of my rims was cracked in six inch intervals around the entire rim. They replaced the rim at no cost. They were able to show it was a factory issue not something I did.
So far I have had an extremely positive experience with Corvette at literally every turn. I shouldn't be worried but I have read a lot of horror stories.
Is there anything for me to be worried about? Has anybody experienced this type of mechanical failure?
I rarely say anything on here but I want to say thank you to everybody that posts. I read the forums on my iPad every night before bed. Nothing puts me to sleep faster. Just kidding
-Anthony
Hopefully it is the battery, but if you have been driving the car to and from work that should keep the battery charged. Ask him what the codes were. Codes normally will show up on your DIC. So it would be interesting what the history codes were.
Have any of you heard of this issue before?
The other stuff may have happened due to a low battery. You should ask them if they checked the battery charge as it is unusual for an ECM failure to cause failures in so many other systems including the ABS and power steering. Traction Control and Stability Control can be affected by ECM issues but the ABS runs separately from the engine.
If you don't drive the car much you may see this situation reoccur.
Bill
If it was me i would pay to have the car flat bedded to another dealer that has a good verifiable reputation. Good for you everything should be covered under warranty.
BTW I've had the Kumho's on for 2 years.
-Anthony
CONTINENTAL
EXTREMECONTACT DWS 06
315/35ZR20
Sidewall Style: Blackwall
Load Range: XL
For 2017 Chevrolet Corvette Z06 Coupe
CONTINENTAL
285/30ZR19
Load Range: XL
If these are the wrong ones, why did they install them? If they are the wrong ones, what do you recommend as a way ahead?
