Should I get my new 2018 Z06 2LZ aligned for better street tire life?
I received my 2lz 2018 z06 automatic last week and since i have put 50 miles on it. Its my only car and my daily driver. Wont be going to the drag strip or track. Should I have a wheel alignment done for LONGER tire and brake pad life on the street? If so what should they set it to?
St. Jude Donor '08
Or you could pass on to the service department, on your first free oil change, that the car is pulling to one side or the other. You will then be given the resulting alignment results which you can compare to the many threads on this forum for the best tire saving settings. I have a version of those setting and my tires are wearing nice and flat.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
If you want longer tire life and you don't drive it like a sports car, you'll definitely want to back the alignment down. Most of the cars we see will wear the inside edges of the tires with any form of a "stock" alignment. We typically back the alignment down if you want to get more tire life.
The following 3 users liked this post by RichieRichZ06:
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Good to hear from a post above that the 18's factory alignments seem to be much better than the earlier Z's. We have not done one yet.
Well over half of those we have done 15 to 17's were out to lunch from the factory. OP if your not looking for all out street or track performance have a shop set the cambers front and rear in the -1 to -1.2 degrees. Keep the toe's front and rear as close to "0" as possible. This will keep the tires wearing evenly. Make sure the shop can check the rear caster and keep that at 0 to positive .5 degrees. If they looked at you like you have 3 eyes when asking about checking the rear caster go somewhere else! Not all Chevy dealers have the proper caster equipment, beware!
My '18 currently has about 1,200 miles on it, no issues to this point but I do plan on having the alignment checked in the spring. My C6 GS was WAY off from the factory, so I'm curious about my C7Z, those Michelins ain't cheap.
Received 1,767 Likes
At 26 miles I took the cup tires off and put forged wheels and street tires on, had it "street aligned" at my local Chevy dealer, they happen to be very good in Corvette service, and mine was off from the factory, drives perfectly now.
I put new skins on my '14 Z51, the fronts were worn on the inside worse than anywhere. After I got the tires on I drove over to my shop where they confirmed that my alignment was factory bang-on. This leads to front tire inner wear cause I think it's the camber that is set negative. I had them put the setting for more favourable tire wear. I didn't notice any different handling issues OTHER than front tire skipping at low speeds was now gone.
Just got an '18 Z06 and the same issue, front tire skipping so I assume the specs are for the track again. Haven't brought it in yet and still debating whether I'll change it. I did get 42000km (26000m)out of the other ones so not unreasonable. Probs would've got a few extra thousand but the rears were worn more, of course, so if you light up the rears once in awhile, they should all wear out about the same time.
Argull (01-19-2018)
Supporting Vendor
St. Jude Donor '08
Front:
Camber -.4 to -.5
Caster: In spec
Toe: 1/16 total IN
Rear:
Camber: -.3 to -.4
Caster: 0 to +.2
Toe: 1/16 total OUT
Anything close to those specs should get max life and not completely kill the handling of the car.
0-500 miles is not allowed due to vehicle tie down during shipment/transportation etc. Vehicles are required to be driven over 500 miles before attempting to correct alignment issues. These guidelines are virtually the same for wheel/tire vibrations or imbalance issues.
501-7,500 miles: Customers are expected to have a valid complaint of pull or other alignment related issue. Dealers are to confirm measurements and adjust alignment to correct the customer's concern. Before and after measurements are required for submitting the warranty claim to GM.
7501 + miles is not a warranty item unless there is a failed part that has caused the alignment concern (tie rod end or other suspension part etc). Dealers do have a little room for a policy adjustment on a case by case basis, but that is very rare and would have to be an extreme circumstance.
RICH
The following 2 users liked this post by RichieRichZ06:
Lyn Go Fast (05-26-2018),
pkincy (01-19-2018)
Received 1,817 Likes
If you managed to get 26K miles out of your stock tires, I'll assume that you didn't do much aggressive cornering.
No, you should take it to the track where Z06's belong. This aint no base model convertible.
hey that looks exactly like mine! stage 1 aero, same color and rims etc. GOOD CHOICE!
https://i.imgur.com/KlaCYj3.jpg
My 17 Z06 the fronts got uneven wear, the camber is too aggressive from factory so inner treads are wearing out faster than outer ones. I can really feel it with my finger, the outer tire tread maybe have 1/2 less wear than the inner ones. Car only got 2500 miles and it's really noticeable.
So just have an alignment that's for street use and less camber, and hopefully it will wear out evenly eventually? you don't purposely make the camber the other way to counter the uneven wear right?
Also saw this in the manual, do I need to print this out to the alignment shop or they probably already know? "Alignment should be
performed by first removing washers
between the upper control arms and
frame according to the following
instructions: Z06 - Remove maximum of 1 washer per front upper control arm bolt. Do not remove wash "
