Brake Squeal
Old Jan 20, 2018 | 11:23 PM
MacRoadie's Avatar
MacRoadie
Default Brake Squeal
So, one (or more) of my CCB brakes developed a squeal overnight. Not a high-pitched squeak, but more of an old school brake-dust type noise that only sounds off at the end of a deceleration, like below 10 miles per hour and can be controlled with modulation.. Zero scraping or grinding and the braking force is nice and even. Debris on a rotor maybe?
Any suggestions?
Old Jan 20, 2018 | 11:33 PM
Bill Dearborn's Avatar
Bill Dearborn
Check the outside brake pad thickness by looking through the wheel spokes. The inner pads wear a little faster but that is where the sensor is located and you can't see them without removing the wheels. If the outside pads have a lot of meat the inside pads will probably be sufficient thickness as the wear rate isn't that much faster. If nothing wrong with the pads then don't worry about it.
Bill
Old Jan 22, 2018 | 08:10 AM
sammyv's Avatar
sammyv
I would do 6 or 8 aggressive 60-0 stops.(put some heat in them) See if that helps.
Old Jan 22, 2018 | 07:58 PM
jerho's Avatar
jerho
Got a 2016 Z with approx 2000 MI. CC brakes squeal like a stuck pig. Appears to be no remidy. What's next? I certainly do not know.
Old Jan 23, 2018 | 07:28 AM
robwah's Avatar
robwah
Sun Devils
There is a service bulletin to fix that. I don’t remember the TSB # but had it done to my 2014 Z51 and my 2016 Z06
Old Jan 24, 2018 | 12:35 PM
MacRoadie's Avatar
MacRoadie
Hmmmmmmm
Old Jan 24, 2018 | 01:28 PM
HorsePowerObsessed's Avatar
HorsePowerObsessed
The Stingray did not come with CCB so odds are very good this doesn't apply here.
Old Jan 24, 2018 | 11:14 PM
robwah's Avatar
robwah
Sun Devils
Both my 2014 and 2016 Z06 do not have CCB. Dealer fixed squeaky brakes per the service bulletin. No charge on either.
Old Jan 24, 2018 | 11:17 PM
robwah's Avatar
robwah
Sun Devils
Service Bulletin: #17-NA-040 Brake Squeal or Squeak Noice Intermittently on Initial Brake Applies - (March 7, 2017). This bulletin replaces PI1496C and PI0917F
Old Jan 25, 2018 | 09:47 PM
oshvette's Avatar
oshvette
Took my car to dealer for squeaking brakes (CCB), they told me about the bulletin and "fixed" it. 20 miles later, brakes still squeaking. All the time, hot or cold.
Old Jan 25, 2018 | 10:00 PM
robwah's Avatar
robwah
Sun Devils
I would take it back. I don’t have CCB and mine are quiet as can be now. Good luck
Old Jan 26, 2018 | 01:01 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Guys buy them for looks. To me they remain the most over rated option!
Try washing the brakes or at least spraying them off with water real good then if the noise goes away it is the dust build up from the pads. Not sure it is the issue but on steel brakes it sure can be the stock pads put off so much dust it
causes the disc to squeal !
Old Jan 26, 2018 | 02:06 PM
thebishman's Avatar
thebishman
Did you follow the street burnishing procedure?
Old Jan 26, 2018 | 02:36 PM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Carbon ceramics are known to squeal, not just on Corvettes. Burnishing can help but often times it comes back. It is a track oriented package with stiffer suspension and calibration. Google carbon ceramics squeal and spend hours reading about all the different makes and models experiencing the same thing.
Old Jan 26, 2018 | 05:01 PM
thebishman's Avatar
thebishman
Drove my Z07 for 2 1/2 years and almost 10K miles. Burnished the CCMs; tracked the car multiple times; kept the wheels clean, and did a couple of ‘hard’ stops if I began to experience any minor squealing. Otherwise the brakes were pretty damn silent; much more so than most high performance iron brakes with the appropriate pads.
Bish
To Brake Squeal
