When zeroing the shocks is this a typical output. The little box states SUCCESS but numbers are all over the place like LF at 0 and others 1800 to 2000. Just wondering what others typically see. Thx.
Ok I m gonna post up the “YAY!” Again. I went back , took out the controller and found the fourth pin on the single row bent Blech. Straightened it, reconnected and got a reading in the 1900s when zeroing. Makes me wonder what the default cation is for the shock if there’s no communication. Or maybe it’s only limited communication. Anyway I’ll see what happens next time out. Thanks for the responses. They helped!
Yep spearfish and everyone else nailed it if you get zeros key was not on .
Good job your zeroed
