Whine in neutral with clutch out
So my M7 has a pretty noticeable whine when sitting in neutral with the clutch out. When you press the clutch in the whine goes away. While it's not awful, it is loud enough to hear over the radio and A/C when sitting at a light. First dealer I took it to was horrible at communicating with me and stated the tech couldn't couldn't hear it. Got tired of non-communication with my service writer so just picked i up. Took it in for 5 things and they fixed 2 just FYI. Took it to another dealer today and was told this whine is "normal" and "they all do it". From ones I have seen and from what I read some do and some don't. Does yours? Also, sometimes when I go to take off I hear a HORRIBLE metal on metal sound. This only happens maybe 1-2 times a month so I know the dealer won't ever hear that but it sounds like a throughout bearing issue to me. Maybe it's normal once you get some miles on them? Mine has about 23k on it and has done it since I bought it 3K miles ago.
Received 2,682 Likes
2018 C5 of Year Finalist
Have you checked the fluid? Any leaks? It's definitely not normal.
No leaks. I changed the diff fluid when I got home (drove it across the country) because it had 20K on it and had heard the cap is only on hand tight from the factory (which mine was) and it looked rather dirty. I normally do my oil changes myself but since I was taking it in for this issue and the suspension update I figured I'd let them do it so they can check to see if there are any other issues. But it has made the noise since I got it. I guess if he calls me next week and says that is normal I will ask him to go start a few on the lot and see if they all do it. If they do, I will accept that it is "normal".
Received 8,930 Likes
It could be something in the clutch but I suspect it is something downstream of the Clutch. When the clutch pedal is out the clutch is engaged and everything is spinning together including the drive shaft inside the torque tube and the transmission input shaft.
Usually when you want somebody to diagnose a noise you need them to ride with you otherwise they may not notice it until you duplicate the exact conditions.
Bill
Bill
Bill
Bill
It only does it at idle (that I can hear). I had my service writer listen just so once again I didn't have this dealer telling me they couldn't hear it. He was the one that said that was normal saying the few he has driven all made that noise. He was outside the car and you can't really hear it with the motor, exhaust, etc. when on the outside of the car. We will see what the tech says this week when they look at it. As I said, you can easily hear it over the A/C, and radio when inside the cart and the motor and exhaust noise is muted from sound deadening so it's pretty significant. The occasional metal on metal sounds is what tells me this is not normal.
Bill
I've had a C5, and C6 Z over the past 15 years so I do understand that once the clutch is released it spins everything back to the transmission. So some noise is "normal". But this sound is NOTHING like those cars. Think how loud your A/C is at full blast; I can hear it over that.
2005 mine too...
Yeah I have suspected a the throw out bearing from day one but after the second dealership has stated that noise is normal and/or blames it on my MGW shifter what am I to do? I said if that noise is normal lets go listen to another on the lot but they stated they didn't have a M7 car on the lot to compare it to but all the others that came in make that same noise (which is BS). And the metal on metal "whine" it makes occasionally when taking off from a stop is getting more frequent; though it isn't happening enough that I know it will do it when I take it in. At least the last dealer acknowledged the noise and stated they talked to GM about it (probably another lie) but better than the first dealer saying they couldn't even hear it.
I don't think it's normal either. I don't hear it on my m7. What year is your car? If you still have a few more years on the warranty you might be better off not doing anything. In the meantime find a dealership that works on a lot of vettes and knows what they're doing. If not you might have more problems after they fix it than you had before.
I know it's not normal, everyone on here knows it's not normal (it seems) and anyone that knows anything about a manual transmission knows that the symptoms are exactly what the throw out bearing would be causing the problem. So the issue is finding a dealer that will actually work on finding the problem. I live in Kansas City so I took it to one of the largest Vette dealers in the city for the first time. I had a horrible experience with this dealership about 14 years ago with my first Vette but figured surely stuff had changed with them that time. Boy was I wrong! They were the dealer that stated they couldn't even hear the noise. But even without that issue it was a horrible experience there. The service writer refused to call me back so nothing could get resolved. Even asked for the suspension software update to be done (that I would be paying for) and she couldn't even do that for me. Since I was told I was the car was ready (not by the writer) I went in to pick it up and they couldn't find my paperwork, then tried to charge me for warranty work. I explained lack of communication was a major issue (my writer wasn't there that day). The place is a joke so I have no desire to go back to that one.
So I took it to dealer #2 which where my service writer there said all he has seen make that noise. Hey, at least he admitted hearing the noise. And their "transmission guy" said it was normal. "GM" says it is normal. That is when I requested to listen to another on the lot but of coarse they don't have an M7. And then they said if anything was causing it the noise it was from my MGW shifter transferring noise into the inside.
The car is a 2015 so I still have about a year and a half left on powertrain warranty; hopefully I can get it straightened out within that time. At least it's just an annoyance rather than something critical but sucks that a $90k car has some odd noise that no others have and I am being told it is normal by the dealers.
Sounds like a problem with the Torque tube. There are bearings in the torque tube that are not serviceable. Link...https://www.corvetteforum.com/forums...rque-tube.html
The test for a throwout bearing is to put light pressure on the clutch pedal but not enough to disengage the clutch. If the sound changes or goes away it is the throwout bearing, if not it is something else. In these cars the something else is the torque tube.
