Need Callaway SC757 advice
Am considering the SC757 upgrade to my 2016 Z06. Base package does not include any exhaust upgrade / modifications. Will I receive all the benefits enabled by the upgrade if I keep the OEM exhaust system? Would the addition of a set of headers be advisable? Comments please. Thanks.
If you have mileage on the car, the warranty will be reduced accordingly.
Enjoy the conversion!
The following 2 users liked this post by BHANSON:
Callaway Chris (02-23-2018),
gshirst1 (02-24-2018)
I have a 2016 Z06 M7 Callaway without the exhaust but with the shift linkage mod. Their exhaust does not add any performance or HP. Headers should not add much performance, are noisier and stock headers are well designed. The shift linkage works very well. The engineering of the entire upgrade is well done.
Former Vendor
Long tube headers, not advisable. Thank you - C.
The Consigliere
Received 5,447 Likes
OP - Callaway's exhaust doesn't add to performance, but if you can comfortably swing it, I say go for it. It's a huge improvement over the stock exhaust, and I'm very happy I included it on my package.
The following 2 users liked this post by OnPoint:
I have a 2017 Callaway 757 M7 without the exhaust, but i thought while researching my decision on the exhaust someone at Callaway said it gains 7 HP somewhere in the RPM range.
Former Vendor
Most I know who have LT headers end up disliking them due to cracked collectors, flange issues, poor fitment issues, and not being able to pass their state emissions tests without a wing and prayer. Performance-wise, it would be not be worthwhile in our opinion.
I have a 16 Z06 Callaway and considered their exhaust, primarily because of the it looks. Like the D shapes.
The reason I did not include it is simply because I like the sound of the factory system period. You can't go wrong whichever way you choose.
BTW the Callaway package will leave you breathless.
China knock offs etc. But when you buy a quality header. The issues are you mentioned are just not there.
I have ran 3 ARH that I have drop shipped to JETHOT for coating.
On my last 3 new Corvette's.
You simply cannot compare it to stock exhaust. The coated header is far superior.
My current 2015 Z06 picked up 36 rwhp with even more under the curve with tune and headers over the stock exhaust.
The car loses about 30-35 pounds of weight mostly towards the front.
You lose two huge cereal box size superheated cats connected to the
heavy hot cast or stainless heavy manifolds.
ALL Replaced by 4 lightweight coated tubes..
Your under the hood temperatures are noticeably reduced and oil temps and running temps are slightly reduced as well.
Cooling is more effective.
The 2300 supercharger will work better with headers installed but they can be illegal for them to install them.
My car is being prepped for the 2300 install later this next week
Former Vendor
dont waste time on headers. Do my cat delete kit with x pipe option.
https://www.corvetteforum.com/forums...elete-kit.html
look at the post i put up few days ago. Guy went from headers to my cat delete kit and wont be putting headers back now.
