Houston we have a problem!
Seems old Co speed was preaching and we should have listened.
My Z06 Charger on the unside bottom of the internal intercoolers and the valves show pretty bad build up.
I'll be calling David at (M&M Mighty mouse. He has the fix to stop this correctly! Need buy 2 kits add to my 2017 as well before it starts down this path.
The 2015 will get a top end cleaning and new 2300 blower and the fix for no more oil to the intake. The 2017 gets the fix too.
The port injection is making sense!
Glad my 2016 toyota and 2018 Audi both have port and direct injection
In this other thread you were opposed to the catch can and venting.
At least your coming clean.
IMO
Snake oil for your Z06. GM is not having the issue that many Di engines do.
My blower was removed at 10k and they were clean and now it next week I'm swapping blowers @29k this time to the 2300.
So I will get photo's up. So we can see!
Other like Toyota and my coming new Audi have port and Di injection both to solve the issue.
Least I actually work on my own cars. I also have an idea how this stuff works Do you?
At 10,000 miles it seemed it was no issue. I spent 500 plus on Catch cans hours of playing with them ended up with the junk still on the shelf
The snake oil depends on the catch can design and installing the catch can in itself can be snake oil if it doesn't work.
Gluing your PVC shut was a stupid idea. MM doesn't do that!
I feel I need the Mighty Mouse solution. All more than JUST a catch can. Just ordered two full kits from Mighty Mouse!
he is the one who put more effort than anyone to fix the issue. I bought an "Elite Catch can" and an all the stuff and it was snake oil. Filled with far too much oil that was clean. I played with it and it never worked right.
Ok I was a little hard on them they all working on the same issue. Just ordered two complete set-ups for the Mighty Mouse Solution! David has really done really well on tackling this issue
in the correct way. Glad I caught this now!
I like the MM can design. Do you still have to pull the lid to plug the hole? I can't remember.
I just thought it was funny that with all the reports, including yours at 10,000 miles, I was starting to think I don't need a can on the Z. Just seems like lots of opposition in that other thread. Now a week later we are back to needing one with what looks like proof of an issue. I don't know, maybe the buildup you are seeing wouldn't hurt anything before you do a rebuild anyway?
I like the vented can, but you made fun of that too. Are the MM cans still vented or do they have another solution to that now?
3 Z06ZR1 (03-05-2018)
Will not plug or glue the PVC closed tried that 3 years ago. Not good answer in my book.
I was thinking it wouldn't be a major issue where it is sort of is more so to the intercooler, but now I do.
Port injection is not affix for the intercooler getting oil.
imo
It sure is building up! A top end cleaner should help clean that up, but I would do some research to make sure it is compatable with the SC.
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
OP thanks for the pics and its just as i suspected. The intercooler fins are the most concerning for us track rats. I'm installing the vent \ bypass tube under the SC soon so will be pulling the SC. I have 25k miles and most of it with the Elite \ CS can that by the way other than WOT works great. We will soon see if that statement is completely true!
I understand your concern.
I just looked at mine at 82k miles. I didn't think to take photos.
I saw some build up on the valve stems at the mid point where the stem retracts into the head but nothing significant on the back side of the valves themselves. Actually the valve itself looked pretty darn good.
The build up on the stem the was soft and gooey.
I cleaned it off of course.
I have been thinking about it and I am not sure if it is actually a problem or what problem it could cause.
Everyone will have their opinions. Of course
BOBSZ06 (03-06-2018)
I can agree with valves stem not real concerning and the backs look good but the intercooler is getting gunked pretty good. You have to pull the charger and filp it to see.
No big harm yet new blower fixes a lot and then I'm cleaning my heads.With GM head cleaner spray should clean up nice.
But don't want anymore gunk in there or in the new blower an M&M has a nice way to do and still maintain like function of the PVC.
Red Devil (03-05-2018)
Can each brick be unbolted and pivoted for cleaning without draining the IC circuit? That's the biggest potential issue you'll face. Once you get air in the circuit guys have had trouble getting it properly bled again.
I've watched my IAT2s on track in hot weather and they're always under 115F. Seeing oil on the IC fins and actually having a cooling issue are two very different things.
Mad Dog 24 (03-06-2018)
this place is so emotional. well said that one week we need them one week its snake oil... in for more r&d and I don't doubt ill be buying one soon as well
Received 2,382 Likes
