Warning Buying Out Of State Z In CA
Here is the problem. Even though Fed Emissions and Ca Emissions are now the same the option code is different. So a non Ca sourced car will have the Fed Emissions option code and the Ca sourced car will have the Ca Emissions code. Only the sticker shows it both ways. Those things are as good as gold.
I wonder if buying a hood from a wrecked 2017 would work. I notice mine does not have the vin on it but does have the 2016 on it.
My company builds medical devices. I get the over compliance and dollars needed to sell a product in CA. If one of our products gets shipped WITHOUT a sticker, one can't be installed in the field. The sticker can only be installed at the factory.
Bottom line is I will WIN in all of this, SHE is mine.......
Good grief ! What a massive PITA to serve the bureaucracy in Kommiefornia.
"Hi, we're from the CA government and we're here to HELP you !"
Good luck in defeating the bureaucrats - hopefully a GM factory-provided compliance sticker will likely solve your miserable (...and utterly idiotic) issue.
Your efforts and additional money spent will yield no cleaner air; that is the "beauty" of the bureaucrats. Ughh....!
Jnape (03-20-2018)
get in-touch with the selling dealer ,and have them get you a sticker for your vin,thru GM parts or zone office,we had to get them in the Cadillac bodyshop I managed ,all the time
put it on and your good
or just get an neveda address and reg it there
Source out a wrecked hood, buy it for a few bucks, heat gun the sticker off and transfer to your hood. Should be good to go.
Hopefully the hand filled out form means your VIN isn't in the CA system because if it is even once the correct sticker is on the hood you may still have hoops to jump through. For this reason I would follow the advice of others to go through the GM dealer to get the decal rather than acquire one from a parts car so that you will have the proper paperwork trail back through GM to use as ammo fighting your way through the state bureaucracy.
Jnape (03-20-2018)
I wonder if the sticker would come off with a heat gun and maybe Heptane to deactivate the glue binder, then transfer to the new hood?
I'm going to assume that, being an emissions sticker, it's important that it be HARD to move from one vehicle to another (which is not what you're going, I get that). If you can get a new decal from GM, that's the answer.
Jnape (03-20-2018)
Jnape (03-20-2018)
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The dealer should have known that detail. When I ordered my Z thru a dealer in Wisconsin, Mike Reilly brought that up, and CA emissions RPO was added to the order. Is nothing but a damn sticker. My Z has 4 cats like everybody else.
The following 2 users liked this post by PLRX:
Jnape (03-20-2018),
motodavid2000 (03-20-2018)
Jnape (03-20-2018)
Received 3,994 Likes
Reason #532 why I will never live in California (this from the guy who lives in the Peoples Republic of Illinois). Sorry to hear that. Best of luck.
The following 3 users liked this post by Big Lebowski:
The following 2 users liked this post by Jnape:
mcoomer (03-23-2018),
#33
May need to hire an attorney so you arent given run around at DMV. I was aware of the 7500 mile rule but shouldn't be applicable in this instance.
Jnape (03-20-2018)
#34
I also got a pic of the original sticker from the original owner.
Let's hope DMV puts down the Crack pipe and gives me the VIN Verification.
Mark Ca (03-20-2018)
#35
Good luck! And look at the bright side that you have had a VERY memorable Corvette purchase experience
Jnape (03-20-2018)
#36
The original owner apparently never burnished the brakes. After a spirited run on my local mountain roads I had a real pucker moment when I had a BIGTIME green fade. Time to Burnish these bad boys.
#37
Sticker is key - when I went shopping out of state, I made sure it had the sticker. I ending up ordering my Z shipped to CA with a courtesy delivery (and CA code), which they registered it at the CA dealer. I also shopped many dealers who would send me photos of the sticker for CA before I made the purchase. The dealer should have know this or at least add the correct sticker on the hood. They should resolve this for you.
Jnape (03-20-2018)
#40
Out of state. Z in ca
You are a funny one.... libs did this to you? Is it a factory hood? Sounds like you can't find your behind with both hands. So you buy a vette from across the country and don't research first then blame the state?
