Please help. Engine codes after spark plug change
Old Apr 22, 2018 | 02:06 PM
1QUICK Z's Avatar
1QUICK Z
Default Please help. Engine codes after spark plug change
Hey guys, I replaced my spark plugs (with the same factory plugs) earlier today and now I'm getting two engine codes (P0033 and P0034) and it's running like crap. I did have to remove the circuit box under the hood to gain access and forgot to disconnect the battery first. Not sure if that has anything to do with my issue? I do have a custom tune and I'm really hoping that removing that circuit board didn't wipe it out?
Please advise. Thanks!
Old Apr 22, 2018 | 02:12 PM
JHEBERT's Avatar
JHEBERT
Bad bypass solenoid, or fault in the circuit. Check every fuse would be a good place to start. Don’t ever pull that fuse box without disconnecting the battery, but I know it’s real easy to forget
Old Apr 22, 2018 | 02:38 PM
1QUICK Z's Avatar
1QUICK Z
Thanks. I'm hoping someone else has been through this and can help me out. Not sure if the custom tune has anything to do with anything?
Old Apr 22, 2018 | 03:48 PM
1QUICK Z's Avatar
1QUICK Z
Just disconnected the battery for 20 minutes and rechecked all of the hoses and circuit board under the hood. The light is now off and it's running perfect. Whew!
I did think it was interesting that the DIC had me run both of the power windows down (separately) and then up again. Once I did this and checked the "ok/check" button, it didn't come back on. Seems odd.
Old Apr 22, 2018 | 04:19 PM
JHEBERT's Avatar
JHEBERT
It told you to do that so the windows could “index’ themselves, common after power has been removed and then restored.
John
Old Apr 22, 2018 | 04:35 PM
1QUICK Z's Avatar
1QUICK Z
Gotcha. I've just never seen that before when I've disconnected the battery.
To Please help. Engine codes after spark plug change
