How much does it cost to color change stock wheels?
How much does it cost to color change stock wheels? Also can anyone help do it in San Diego? Looking to go red or flat gold.
$75 to $125 for powder coating is pretty much the norm. I had my CTS-V coupe wheels done. Changed the plain looking nuburgring flat black wheels into galaxy gray.
Love those gray wheels. I never have dug in to the black wheel thing and I absolutely detest chrome. The gray is the perfect mid ground between the aggressive look and a little bit of sparkle to see the shape of the wheel. Nice
Received 2,681 Likes
2018 C5 of Year Finalist
[/QUOTE]
Those look nice. Budget $500 for a pro powder coat treatment.
[QUOTE=cvp33;1597322590]$75 to $125 for powder coating is pretty much the norm. I had my CTS-V coupe wheels done. Changed the plain looking nuburgring flat black wheels into galaxy gray.
Did they strip them? Sand blasting can eat the wheel. seems awful cheap
maybe you mean per wheel?
You can Plasti Dip your own for about $50. They are not permanent but they do last more than 6 months. This makes it easy to change color anytime. We did my son’s wheels about 8 months ago and are going to redo them in a different color in a couple of weeks. Easy to do and the overspray peals right off of the tire so you don’t have to dismount them. You can also go back to stock color anytime.
This is finest looking powder coated wheel I have seen! DocsZ wheels has 1 set left MAYBE left!
It's usually around $100 a wheel for powder coating. I decided against powder coating since the factory wheels are known to be somewhat fragile and the powder coating process can weaken the metal.
Plasti-Dip has come a long ways and looks really good now. I dipped my factory wheels in bronze for a month or two until I purchased forged wheels. The only down side I've experienced is the Plasti-Dip can peel if you get petroleum based tire shine on it. Other than that I've had Plasti-Dip last 3+ years and still looked great.
Genuine wheel manufacturers prepare the aluminum properly for the powder coating process prior to baking.
You really don't know what you are getting or doing to a wheel when you send it to a powdercoater.
I'd say strip them and have them painted to be safe.
JMO. YMMV.
I had my chrome Z06 wheels powder coated black. I also had them do the center caps and lug nuts. That, with taking the tires off and remounting and balancing was 650. I'm assuming mounting and balancing was around 150 so yeah I was at about 125 a wheel.
That is the point that everyone needs to be aware of, the baking process is not the same with aftermarket powder coating as it is at a genuine wheel factory and CAN potentially weaken the wheels.
JMO. YMMV.
JMO. YMMV.
Wrapping the wheels any color you want seems to be picking up. Check out all the YT vids. I don't know how much it is though...
