Can a 2019 Z06 be tuned?
Was thinking of a 2019 Z06 but will want to get it tuned if I do!
Thanks in advance!
Thanks in advance!
I think it has no changes from the 2018 as far as ECM is concerned and is tune-able. I do think the 2018 and 2019 cost a bit more to tune though, because of a change to the ECM from the earlier models.
Thanks pondering to buy a 2019 but if you can't tune it I would rethink the move.
vdavenp802 (06-06-2018)
Super Spartan (06-23-2018)
Received 1,817 Likes
The following 2 users liked this post by Warp Factor:
bgspot (06-05-2018),
Well for one thing you get a brand new car. My 2015 is fine but has 32k and was repainted on GM's dime. The cooling is not a factor still deciding. The interest is the fueling I heard has been upgraded. 2019
ZR1 and Z06 carry the same fuel system. Thus I think why Weapon X is getting more power on stock tune and fueling. I know only the ZR1 has the port injection and direct. The 2019 Z06 may do better with the same mods. I could just get a repaint on my dime and call it good.
Not much cost to up grade the cheapest Z06 still is 55k and the new one is discounted to 74k so less than 20k gets me the new one.
4 model years newer lots of better tech.
Color choice is a bite I love the silver but thinking of the freaky orange.
I would swap all my current mods to the new one. New parts back to the 2015 even the seats I want to keep my comps. I might do better than I think IMO No warranty worry on the M7.
The only worry is slight when I tune the A8.
The mods make the car alive with 800hp (675 rwhp) Light weight stupid fast!
I see a 3 Corvette line up! 2019 Z06 M7, 2017 A8 both with my 2300 builds and then add the new ME. Done!
The Consigliere
Received 5,447 Likes
So you're gonna get rid a '15 Z06 M7 modded the way you like in the color you like, to get a '19 Z06 M7 and put the same mods on it?
Unless you're wanting to change color, seems like a waste of time and coin - but heck, it's your bucks, so do what flips your skirt.
As to the tune, has your tuner done a '19? They've been out for a while. Wouldn't be surprised if he's already seen/tuned one.
Insurance was about 1300 for 2 Z06's 12 months Pretty super!
Not sure on the tuner on the 2019's. Lots of flexibility, Since I'm swapping blower and exhaust.
My 2015 will going with a upgraded 2017 blower and exhaust, 2019 seats and new 2019 wheels and tires. Should sell easy.
Not sure on everything new but the engine is still just DI but better fuel I heard.
I'm Batman..
Pro Mechanic
So, in short, there are NO upgrades to the Z06 fuel system since its release in 2015.
Only upgrades the Z06 will see in 2019 vs 2018 and prior is a different tooth pattern for the rear diff which will make it stronger and different rear upper control arms for the M7. Thats it.
Here is the article where I asked Tadge about it and he confirmed the low side upgrade for the ZR1: https://www.corvetteforum.com/forums...sed-power.html
Ant
Im not sure what you “heard” but thats completely wrong. The ZR1 high pressure fuel pump, and injectors are the exact same as the LT4. The ZR1 has a low pressure fuel pump that is improved flow over the Z06 but that is ONLY on the ZR1. The ZR1 is indeed the only C7 that gets port injection.
Ant
Ant
So not quite completely wrong. Plus read what Tadge said again "we had to add fuel capacity for the Lt5".
Didn't say the Z06 didn't get the upgrade. Your saying the 2019 ZR1 and Z06 carry different low side fuel pumps? Not real sure on that yet I maybe wrong but I think I heard different and sent the question back to my sources. I already have some more questions. There are numerous other changes.
in the cars as well. Besides what you mentioned from the 2015 to 2019. Its an improved car they don't get worse on the same model.
SUPER GOOD NEWS!
My dealer tech says your wrong SAME low side in the tank pumps FUEL PUMPS 2019 ZR1 and Z06 same part number!
Which means very good for me and 2300 build. 675rwhp where I'm at should move considerably higher!
