Detailed review of a Mamo Motorsports ported TB
#41
Supporting Vendor
An LT1 or LT4 is both the same.....I just need to know which version you need when you order
Shoot me an email or a PM anytime if you would like to get in the work queue
Lead times are about two weeks
-Tony
#42
So my '19 Z has the larger ZR1 TB? Interesting? Was that just done to standardize (simplify) production? So you would be polishing/porting essentially a ZR1 TB for my '19 Z06? And the larger stock ZR1 TB does nothing extra for my '19 Z06? I don't understand that? So I will need to specify the TB is for a '19 Z06 - correct? I will get the car in mid-Sept. What is your lead time - generally?
#43
Supporting Vendor
All the others are the same as the LT1 and LT4's from 2018 and prior
When you order the TB just specify its for a 2019 Z06 and we should be fine
-Tony
