LT4 upgraded injectors?
#41
#42
#43
crawford racing made 841 rear wheel with the non zr1 in tank pump via port injection.
the zr1 has a pump that pumps 20% more fuel, and this same pump is in the 2019 z06 drivers tank as well.
Would you be so kind... to let me know... what 20% of 841hp please, and then add that to 841...
so, what is 120% of 841hp?
I'll let you supply that number, since I know if i do, youll argue with that also.
Granted, i think the 841 number was with a turbo, more efficient than our blowers of course... but you still get the idea. Thats why i took it from 841 down to 800.
so whats 120% of 800... a number near 1000?
That is your aprox answer. And I didnt say EXACTLY, i said near 1000.
You are the most annoying creature on this forum, I hope you realize that.
Thank you! You win the prize of self proclaimed know it all on any subject ! But too easy to figure out it that you really don't know! You are the most dense headed! Better take it down even more! The lt4 runs out of fuel at 675 or 800 CRANK HAHA! you are way off and clueless! With out supporting mods it is not even doing that! Modded way more corvettes than you pal!
First off has anyone added this pump to the LT4 and made it work? Please leave the turbo out of the conversation. Your not running one and nor am I. Last I read from following ben at Weapon X it DOESN"T WORK obviously Ben knows the most on the forum about the port injection and the Zr1 fueling and tuning on he ZR1. Ben has also said the ZR1 pump is no where near 1000w ! But doesn't matter if you cannot use it!
#44
when you have to push all the fuel through the DI injectors... sure.
When you go through low pressure large regular injectors at each port, no, the pump is able to supply fuel into the chamber much easier when a DI injector isnt in the way as a bottleneck.
That was the importance of crawford racing's findings. 841... at the wheels.... stock pump. Stop arguing, how can you spend so much time on this forum and know so little?
I guess i blocked you for a reason, time to stop getting curious and seeing what you said.
you insult people a lot for being as wrong as often as you are.
#45
#46
We are still finding out what you seem to think you know.
#47
Former Vendor
03 z06zr1 can you just stop. I stop posting in your threads a while ago and you still step in mine. once again im asking you to please stop posting in mine. I dont care what you say or do in your own threads but you keep screwing with mine.
#48
Received 7,775 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Guys, again I had to delete a pissing match. Take it somewhere else-IT MAKES FOR POOR READING. And grow up too......
Jesus......
Jesus......
#49
Received 1,817 Likes
I strongly disagree. Mikec7z's various posts have included some really valuable and thought-provoking information.
