LT4 belt drive differences?
Old Aug 3, 2018 | 12:57 AM
TorchZ51's Avatar
TorchZ51
Default LT4 belt drive differences?
Was there at change at some point to the LT4 belt drive? I have an additional smooth idler circled red in the pic. But other searches show this pulley not part of the belt drive
Old Aug 3, 2018 | 09:46 AM
atljar's Avatar
atljar
2015 is different than 16+
Old Aug 3, 2018 | 10:22 AM
dar02081961's Avatar
dar02081961
Curious.....is the bottom photo of your engine?
If this is the case the difference could be you have a crate engine and not the LT4 accessory drive as installed in the Corvette application.
Not saying atljar is wrong, just my conclusion based on the evidence presented.
Old Aug 3, 2018 | 10:52 AM
atljar's Avatar
atljar
I totally could be! LOL. I just know Weapon X sells different belt lengths for the blowers on 2015 vs other years.
Old Aug 3, 2018 | 02:32 PM
dar02081961
This is Interesting. I would like to be sure in the event I run into this in the future.
The parts manual calls out the same belt for 2015-2017.
These sources could be wrong so who knows.
https://www.gmpartsdirect.com/oem-pa...YtMmwtdjgtZ2Fz
https://www.gmpartsdirect.com/auto-p...d-pulleys-scat
Old Aug 3, 2018 | 02:34 PM
TorchZ51's Avatar
TorchZ51
Can anyone confirm if their 15 or 16 has the additional pulley circle in red?
Old Aug 3, 2018 | 03:09 PM
Bill Dearborn's Avatar
Bill Dearborn
My 2015 has an idler pulley in that location.
Bill
Old Oct 2, 2024 | 03:42 PM
Hummelj12's Avatar
Hummelj12
I know Im a few years late to this topic, im running into an issue with that bracket. Needed to replace the bracket, I have a 2018, looks the same as yours, but can only find brackets without that lower idler. Also, correct me if im wrong, isnt that belt supposed to go over the top of that lower idler, not the bottom of it.
Old Aug 27, 2025 | 09:25 AM
Hummelj12's Avatar
Hummelj12
Hello, i am having this issue as well, did you ever find a work around, i bought a bracket but it is for the Zl1 with no lower idler and didn't know if that will work due to belt wrap.
To LT4 belt drive differences?
