X pipe install question
Old Aug 16, 2018 | 02:10 PM
jabeasley1's Avatar
jabeasley1
Veteran: Marine Corps
Default X pipe install question
Short and simple. Do I need to disconnect the battery before installing my new Borla X pipe? Thanks in advance
Old Aug 16, 2018 | 02:11 PM
Kracka's Avatar
Kracka
Nope.
Old Aug 16, 2018 | 10:08 PM
Darkvet's Avatar
Darkvet
What he said
Old Aug 17, 2018 | 10:14 AM
1c8vette64's Avatar
1c8vette64
You are just taking off nuts and bolts that hold the X pipe on, so of course not. You only need to disconnect the battery if you are touching something that has to do with the charging or electrical system, like an alternator or starter. Tip for installing the X pipe is keep everything loose until it's all lined up correctly and then tighten down. Very easy job.
Old Aug 17, 2018 | 10:38 AM
llesswon's Avatar
llesswon
And get some lubricating spray to assist with taking the exhaust hanger off and putting it back on.
Old Aug 17, 2018 | 10:47 AM
jabeasley1's Avatar
jabeasley1
Thank you for all the responses. Like most things, I am sure I am overthinking it. Semper Fidelis
Old Aug 20, 2018 | 09:31 AM
jabeasley1's Avatar
jabeasley1
I put the car on the lift and installed the borla X pipe over the weekend. Easy mod, straight forward, and love the louder sound while revving. Thanks again guys
Old Aug 20, 2018 | 02:14 PM
Poor-sha's Avatar
Poor-sha
Track Rat
I am really close to doing this mod for track use and might buy another set of hangers and gaskets to make swapping back and forth easier.
Where did you buy from?
Old Aug 20, 2018 | 03:05 PM
jabeasley1's Avatar
jabeasley1
I ordered from RDP. They were the quickest to answer and had a great out the door price. I ordered on the 15h and literally received it 2 days later. Very happy with the fitment and transaction and speed of delivery.
Old Aug 20, 2018 | 03:13 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Never hurts to think ahead before a job shows you're being smart! Lot of bad can happen with out it! My dad main preaching was to think about things before hand.
If you were installing headers you would sure unhook the battery.. But you should be ok! Good luck!
Old Aug 20, 2018 | 03:15 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Liking that RDP guy myself!
To X pipe install question
