Another Cooling Thread
So far, I haven't been able to find detailed information on the Porsche system, including how they ensure that all the water is vaporized, and none ends up on the track.
Any info, experiences or thoughts?
Their build was posted on here, I’ll try to find it.
1. In some types of racing, like mile events, they have rules that put alcohol-injected engines into a faster category. A buddy had to run in a "fuel" category, though he was using pump gas in the main fuel system. This was a number of years ago, so things might be different now.
2. Lower cost, easier availability. Distilled water can be found in most any grocery or drug store, for about a buck a gallon.
3. Water, once vaporized in the intake tract, will displace some oxygen-containing air. This won't matter, when the water is sprayed outside of the intake tract.
4. Might also be used to cool the main radiator (which would also cool the oil better), and not just the charge air. And that might be fairly simple, having three heat exchanges stacked in a row as we do.
https://jalopnik.com/my-salvage-z06-...-pi-1796489202
" So anyway, we were struggling with an overheating issue. It was enough of an issue that it slowed my last two runs in qualifying. The first of those runs the car went into limp mode about half a mile from the finish of the qualifying sector, and the last run I aborted completely when the temps jumped substantially not long after the start.....
.....we had absolutely no intake ducting. This one was totally on us, with the compressed timeline forcing us to skip things that we would have normally done. With proper ducting, air coming into the front grill would be forced through the radiator. But with our current lack of ducting the air, as opposed to being forced through the radiator, would instead look for the path of least resistance, which would be around the radiator. Clearly not ideal. With no easy access to fabricate the proper ducting we looked for other solutions. The simplest one was to water spray the radiator. My NRG Motorsport guys raided the local Home Depot for some hoses and lawn sprinkler mist nozzles to MacGyver the system.Using our unneeded windshield wiper bottle as a reservoir, we ran a main hose to the nozzles we installed just in front of the radiator and intercoolers. This had an immediate positive effect. Our temps dropped 20-30 degrees and we were able to get several runs in before we hit redline."
As far as drippage onto the track goes, i doubt it, as long as a person has a nozzle that creates a good mist, and sprays it UP or DOWN from the nose intake cavity, all of the heat exchangers in the area will vaporize the water upon contact.
Evaporation is a cooling process, this obviously lowers the temps of the heat exchanger metal, and that in turn is able to offer more heat absorption from the fluids flowing through it. I believe 20-30 degrees cooling is very possible.
What would be very slick is if a person had a type of catch can/res system from the AC condenser and captured the water that drips off of it. Once the can/res was full, the system could be setup to make proactive sprays onto the HX on its own, and then a person would also have a manual override button to spray it onto the HX when they want to spray it, and that can drain the tank completely.
Then another switch could control bringing winsheild washer fluid down to the can/res, IF the can/res went dry (or one could just have a separate pump and nozzle from this washer fluid tank, and keep the nozzles and systems separate. Running the AC or even weaponX etc Chiller for boosted air, would also create water drippage that could be caught by the can/res.
Or, just Keeping it simple with just the washer fluid tank alone, but either way, i think you are correct that this could/should be implemented onto cars Warp.
I don't think it is something anyone needs to advertise to a track that they have. The key is to spray it while they are driving forward, and then all the water would absolutely hit a HX and vaporize. No drippage would occur from the sprayers.
Spraying straight down from above the transmission cooler, would be a great spot. 1 nozzle in the middle would be plenty.
Oddly enough, water could be sprayed onto the supercharger lids themselves from the outside, this would cool them down. The ones that are less insulative like the NX Outlet lid, would be ideal, that lid would be a literal heat exchanger.
I am amazed that no one has created a heat exchanger lid yet, especially callaway cars where the lid is exposed... there could be the return hot water from the bricks going back through the lid, to keep it cool.
Callaway should be using a much more conductive material for their lids either way... like the NX outlet lids are made.
I used such a system many years ago on an air to water intercooler system for a turbo charged 425 hp rotary engine drag car. It was effective in the early spring and late fall when the dew point was in the 40-50's. In the summer, when it was really needed, the system was pretty much useless since around here the dew point is in the 70's during the summer.
A good illustration of the effect is that swamp cooling air conditioner systems are only useful in low dew point locations like in the desert.
That sounds counter-intuitive to me, and I haven't fully digested the entire paper yet, but that's what they came up with in their "conclusions" section at the end of the paper (on the page labeled 316).
I would have guessed that a liquid buildup on the heat exchanger would act as an insulator, but it's looking like it may not, at least not under all situations. Live and learn.
Sometimes, it will take me several reads to fully get my mind around a highly technical paper, so there's also the possibility that I've misinterpreted something.
Here's a link to the paper:
https://deepblue.lib.umich.edu/bitst...pdf;sequence=1
I think the quality of HE offered on the aftermarket isn't always the best. You can spend a hell of a lot on good quality cores if you want. Also you don't see aftermarket companies testing multiple cores and getting real world results. Everyone just seems to sell theirs and say it's the best. What is the best rad on the market? No one knows but each manufacturer will say theirs is!
Here is an example of the testing and selection that some companies out there do (under development tab): http://www.litchfieldmotors.com/niss...er#development
I can see why it might not be ideal for OEM, with the need to add water periodically, or some other need for frequent maintenance, but Mike's suggestion of recycling condensate from the air conditioning evaporator might take care of that, for light occasional use in warm climates. Unless the condensate has already become contaminated enough, that it would grow slime in the reservoir. Pure distilled water is sterile, and will stay clean indefinitely.
The OEMs used to use it on road cars so they could use it on group N rally cars as they weren't able to make any changes to intercoolers etc but would run much higher intake temps. There is no doubt spraying water works but I would rather the heat exchanger work more efficiently than HAVE to use it.
The bit about he aftermarket stuff still stands! There is far too little factual data / proper comparision teating out there.
im not saying it won't work at all! It's a tried and tested method of reducing air temps. Just go look at coal fired power stations that use cooling towers to see it in action. In fact I think that better highligjts the cooling benifits. Spraying water into air also increases the amount of heat that given volume of air can remove (as you have added a shed load of mass to the air). Also the water will reduce the air temp thanks to the water evaporating reducing the air temp before it even hits the radiator.
Howecer that doesn't take away the fact that a better cooling pack would still perform better with or without the cooling spray!
As to the paper it would seem this is an engineering student paper/experiment probably done as an undergraduate senior design/ analysis course. Such courses used to be a requirement in most all engineering schools (this paper is from 44 years ago) to demonstrate some actual familiarity with an actual design of something relevant to the degree being sought. My observation is based on not seeing any degrees/experience citations behind he authors names as is/was always the case for such papers.
If you want to spray something on the fins that really cools, maybe to a fault, NOX is an good choice. The bad news is you may crack the core due to rapid thermal contraction and in an actual race possibly trigger the safety crew from the vapor trail down track.
I actually used this method screwing around during a test day. It was effective however not really practical for actual racing where in later rounds you may have to run back to back with no time to refill the NOX bottle.
BTW it did cause the safety crew to roll from the vapor trail. It did however take the intercooler water temperature into the mid 50's F vs 100+ F with just air flow. I was using a 10 oz nitrous bottle marketed in those days as Sneaky Pete for people running in restricted classes trying to hide the nitrous from the tech inspectors. There were some fine explosions from people trying to use these bottles hidden in oil pans.
