Sponsored by: GEM Motorsports
Stage 3 winglet removal, LOL
Old 09-11-2018, 10:48 PM
SoCalFinest
SoCalFinest's Avatar
Default Stage 3 winglet removal, LOL
Really GM? There is no torque bit in the world that can fit with that extra, super clearance. I'm not the ripest orange in the banana tree but seriously? Lol
Old 09-11-2018, 11:06 PM
BrunoTheMellow
Support Corvetteforum!
BrunoTheMellow's Avatar
Received 1,396 Likes on 999 Posts
Theres actually torxs allen wrenches, 90° angle, don't know if those would fit but i put mine on regular hex bolts (aftermarket winglets). Look the wrenches up. Or you can Use the torx bit on it's own and a pair of pliers, should be enough to get it loose enough to use your fingers.
Old 09-11-2018, 11:09 PM
SoCalFinest
I couldn't even get a torque bit by itself in there lol
I guess I'll have to go shopping for a 90* bit.. I mean the space there is like half an inch
Old 09-11-2018, 11:27 PM
23/C8Z
23/C8Z's Avatar
Received 5,761 Likes on 3,177 Posts
Idk. Have no problem accessing mine. A little manipulation but no issues?
Old 09-11-2018, 11:39 PM
cyi1
cyi1's Avatar
2018 C7 of Year Finalist
Stick just the bit in there and use pliers to turn the bit lol a couple turns is all it needs to slide off
Old 09-12-2018, 12:22 AM
SoCalFinest
I need to find a very small torque bit lol
This stinks
Old 09-12-2018, 05:32 AM
Crushinator
Crushinator's Avatar
1/4" wrench fits bits perfectly.
Old 09-12-2018, 06:25 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
I ordered some products for the house that had to be assembled. The product included a cheap foot long torx bit that fits at an angle into that narrow space and can turn the bolt head. My fancy expensive torx bits are built to heavily to fit into the space but that cheap freebie is perfect. You also have to lower the air dam and the undertray under the car so you can get to the nut on the other end and hold it so it doesn't spin. If you don't do that you won't get the bolt loose.
Bill
Mikec7z (09-12-2018)
Old 09-12-2018, 07:18 AM
BLK06ZO6
BLK06ZO6's Avatar
This. I used a ratchet with a 1/4” drive and torx bit to remove that screw. It’s off angle slightly but wasn’t an issue.
Old 09-12-2018, 07:27 AM
DevilDog II
DevilDog II's Avatar
Oldtimer
I'm sure GM sells a "special" wrench for $100.
rogergcam (09-15-2018)
Old 09-12-2018, 09:58 AM
SoCalFinest
I'm over it, there is literally about half an inch of play if that. There's no ratchet than can fit a torqe bit with half an inch that I can find. Oh well, guess I'm not changing out my spats anytime soon.
Old 09-12-2018, 03:21 PM
HorsePowerObsessed
HorsePowerObsessed's Avatar
Once you get them off replace the torx head bolt for a regular hex head that way you can put a box wrench on the end of it next time (plenty of room for that) and get it right off. This is what I did when I first put the canards on because otherwise I wouldn't have been able to tighten them down originally.
Old 09-12-2018, 03:24 PM
SoCalFinest
LOL.. Not happening so far
Old 09-12-2018, 05:21 PM
nch209
nch209's Avatar
A stretch, but can you find a 90 degree torx allen and then trim it way down with a grinder to get the clearance?
Old 09-13-2018, 12:18 PM
Tennispro1986
Tennispro1986's Avatar
Use a torx but attached to a universal extension then you can pivot the extension out of the way then attach ti to your ratchet to break torque. Then spin it out with your hand. You could just as easily take a pair of side cutters or small pliers and just grab it and turn it loose. It not gonna be on there tight.
Old 09-13-2018, 12:55 PM
byklin
byklin's Avatar
Correct me if I'm wrong but I just recently installed the stage 3 winglets and i don't think you need to remove it to install the spats? You can just loosen the 3 bolts on the back on the winglet
Old 09-13-2018, 01:40 PM
SoCalFinest
Are you serial? Hmm.. I know the Spats have a screw at the bottom and thought the winglet will be in the way. I can remove the 3 screws on the backside of the winglet but not sure if the winglet will get lose after that.
Yeah but you installed the winglet, I'm just trying to take off my spats lol..
To Stage 3 winglet removal, LOL
Old 09-13-2018, 01:42 PM
SoCalFinest
torque bit won't fit lol
Btw your avatar cracks me up everytime.. love it! haha
Old 09-13-2018, 01:43 PM
byklin
byklin's Avatar
Yes, remove the 3 screws on the backside but I don't think you need the winglet to be loose. The spat just sits between the winglet and the bumper so try sliding it out after you have removed the tape and the bolts holding the spat. Let me know if that works!
SoCalFinest (09-13-2018)
Old 09-13-2018, 06:43 PM
trevor90
trevor90's Avatar
some of the placement of screws manufactureres put **** puzzles me.
Quick Reply: Stage 3 winglet removal, LOL
