Driver display not changing
Old Oct 6, 2018 | 03:21 PM
mlski's Avatar
mlski
4th Gear
Default Driver display not changing
Recently my car (2015 Z06) was slow to turn over. So I'm thinking the battery is starting to go. Next time I tried started it up, it seemed dead and message came up that key fob not detected. So I inserted Fob into the key slot and car started up, but my display looked different than I had it set for the previous year i owned the car. Normally I keep it in Touring mode with the performance display set. After this last start up, the display shows the normal display. When I try to switch to performance display, it looks the same as normal display. There's no option anymore to hit left button in right hand side of the wheel under settings and get the link displays option?
I have since put a new battery in and the display situation is the same.
Has anyone came across this problem before?
Old Oct 7, 2018 | 08:10 PM
RonC7's Avatar
RonC7
You don't have the left & right arrows or ability to get to the left or right side menus?
Sounds like a computer glitch.
So - reboot. Disconnect the negative battery cable for half an hour, reconnect, try again. You will need to reindex the windows.
When you get the arrows back, go to left menu / settings -> center scroll to display mode -> right arrow -> select TRACK.
Then back to the left menu and select Info, performance, nav, audio, etc....
(Change your fob batteries too - they are only good for about 3 years).
Ron
