Alignment Advice Needed
New alignment read out is: Left Front: Camber -1.3, Caster +7.4, Toe -0.07, Right Front: Camber -1.2, Caster +7.8, Toe -0.07, Front Total Toe -0.14, Steer Ahead 0.00
Left Rear: Camber -1.3, Toe -.07, Right Rear: Camber -1.3, Toe -0.07, Rear Total Toe -0.14, Thrust Angle 0.00.
So I am driving home, and depending on the road surface (maybe some roads have grooves or crowned) the car jerks violently to the right even under moderate braking. Feels like it is coming mostly from the rear, but not 100% sure. On local interstate, this did not happen with moderate braking. But car is now borderline safe to drive. Car tracks well on acceleration, braking seems to be the issue, violent on some roads... On the Hunter printout, the left front & right front toe readings are highlighted RED as is the Total Toe.
Called the guy back and he says he thinks it is the front toe which was originally positive and now negative. Those readings are in degrees, DSC specs are in mm for Toe?
I am going to take the car back on Thursday. Is the new toe settings the culprit here? Differences between degrees and MM?
Not sure if he changed rear caster at all - no measurement tool (he could not use my angle gauge)
Looking for suggestions from resident techies and racers...
Initial thoughts on your specific alignment.... I dont like the cross camber and cross caster differences up front. I always want them even. Yours isnt terrible, but its not perfect either.
Secondly, its possible to get rear camber in spec, and have caster be WAY out. Moving mine around on the alignment machine, you could get camber in spec and have 3 or 4 degrees of caster in the rear which is a massive change from where factory wants it. This would be my initial guess on whats going on with your car.
BEFORE
FRONT :
Camber -1.0, -1.1
Caster +7.4 +7.8
Toe +0.07º +0.05º
REAR:
Camber -1.0, -1.5
Caster ? ?
Toe -0.07º -0.06
AFTER
FRONT :
Camber -1.3, -1.2
Caster +7.4 +7.8
Toe -0.07º -0.07º
REAR:
Camber -1.3, -1.3
Caster ? ?
Toe -0.07º -0.07
Did the guy tell you why he couldn't use your angle gauge to measure rear caster? It is a fairly simple thing to do with a lot of us forum member morons able to do it. It seems like any well trained and knowledgeable alignment guy should have been able to use the gauge. Or is it they didn't believe there was such a thing as rear caster? However, I am not sure that if rear caster was way out of whack it would cause the pull you are getting under light braking. Rear caster is used to counteract bump steer and you shouldn't be having that much suspension movement with light braking to get bump steer.
Right now the only thing to do is to go with the front toe adjustment and have it set like it was previously. I would also talk to them about measuring rear caster and adjusting it. What type of gauge do you have and do you have the GM Gauge adapter? If you don't have the gauge adapter supposedly two quarter inch bolts will fit in the holes and provide a reference for a gauge like an iPhone if you have the angle gauge app on the phone.
When adjusting rear camber and caster I believe the front arm of the lca affects caster more than it does camber and the rear arm of the lca affects camber more than it does caster.
Bill
Now, in light to moderate braking except on the local interstate, the car is evil - always jerking sharply to the right, I guess because of a crowned road. I asked the guy to use my angle gauge (one of the ones Bill recommended I buy and I do NOT have the GM gauge adapter - I didn't think GM sold it to the public)) and he said he does not have any attachment tool for it and anyway, after aligning corvettes for over twenty years (including Corvettes) I am the first guy to ask him about setting rear caster. I am pretty new to this area, but this shop came very highly recommended to me from several sources in this area.
He also suggested just going back to the original toe adjustment I don't see any problems with the camber front and rear - agree? I will try to get him even out the front caster settings. I still do not understand why the recommended DSC toe settings (he set mine pretty close to them) are causing this severe problem? How could these settings wreak so much braking havoc? Pretty unsettling!
It isn't the settings you have now, it's the rear caster that was changed by him changing the other settings. If he doesn't adjust the rear caster along with everything else it's going to be out and that's what's causing my problems that sound a lot like yours.
However, if you can't get it quickly try using two quarter inch bolts stuck in the adapter holes in the knuckle and an iPhone bridged across the bolts to measure the angle. I don't know if the iPhone is accurate enough but it will get you in the ball park. One of the key things is to remember to zero the gauge to the level of each side of the car. Zero it to the alignment rack on the driver's side when doing the driver's side measurement and then zero it to the passenger's side of the alignment rack when doing the passenger side measurement. If zero'd properly then you don't need to do any additions or subtractions to understand the measurement. It will be displayed in the units you need.
Bill
Bill
* I believe it's now been around for at least a few years, if not longer. Bill D can correct me.
Bill
Bill
Technically, shouldn't it pull slightly to the right since the right side camber is closer to zero (LF=-1.3, RF=-1.2)? Or did you mean to say the most negative camber?
I hope this helps explain this and be careful until its been fixed. I will monitor this thread in the case you find something else. Your final toe specs and everything else does not seem to be the issue to me. Just to eliminate the possibility have the brake calipers checks to make sure clamping pressures are similar. A bit of air \water in one caliper can cause a pull. Good luck!
Thanks to everyone who contributed and helped, especially Bill Dearborn.
