Toyo R888R on stock Z06 wheels
#41
2022 Corvette of the Year Finalist -- Modified
C7 of the Year - Modified Winner 2021
Tires just got here hears a picture next to the stock rears. I will get pictures of the fronts tomorrow when I get them mounted. The width seems to be very close to stock. The stock is mounted and the new ones are not mounted. Height is a little bit higher but not very much. More pictures to come tomorrow.
The following 3 users liked this post by baystealth2430:
marsheng (04-04-2022)
#45
On the car.
Second picture is with the other side of car jacked up. I will get some more when fished and level
#46
I guess they ARE 285/35s. They look normal on the car (though I'd probably have gone with the 295/30s), but why is it sitting so high (in the first pic, not the pic where it's jacked up)? And let's see the rears!
#48
I agree however, the difference between the front and rear tire ratio would that be enough to throw off the ABS when running a 325/30/20 & 285/35/19 versus a 325/30/20 & 295/30/19...
ernhart333 (04-05-2020)
#51
I'm not saying it would. It was more of an open ended question. Possibly asking, the ratio from the factory sizes versus the 295/30/19 is smaller than the 385/35/19 would that ratio difference throw off the ABS.... geez if that makes sense hahaha
#52
I don't think it would. I'm pretty sure the ABS gives 0 effs about wheel diameter/circumference. It's about how hard you're breaking and whether or not you're about to lock em up. Now I'm certainly no expert, so I could very easily just be talking out of my *** and be way off, but from a logical standpoint, it should have no effect. The only effect the diameter of a wheel should have is the speedo and that's only on the rears (and maybe fuel economy a little).
#53
The following 3 users liked this post by Fredforce:
#55
Mikec7z (11-14-2018)
BlackBandit (05-11-2020)
#60
How are they in hard curves? Do you anticipate them wearing out quicker than a cup 2 tire, or more life? Tread looks to be deeper, so hopefully more life in that regard
