Outer Exhaust Pipes Dark - Not Inners
I thought I went through the menus to keep the exhaust open all the time - normally drive in "Sport" mode. Outer exhausts dark as expected, inner exhaust flaps do not seem to be opening? Yesterday during my dyno session, the shop attached some sniffers to the inner exhaust pipe and got zero readings during the first pull. Even during idle, the flaps are not open. Why? Guess it cost me 5 or so ponies yesterday but I am pretty pleased with 589 rear wheel..
SoCalFinest (11-14-2018)
Greg00Coupe (11-16-2018)
I appreciate the diagram, but it does not explain to me why the outers get dark and the inners stay clean. Or why, if I set the exhaust to be open in the engine management screen, the dyno shop guy thinks the inner flaps may have never opened??
There are no inner flaps. Only outer. When outers are open majority of flow goes through outer tips thus black.
turn you system to stealth and flow will be directed through the inners and they’ll get black.
There are no valves on the inner.
Did you look at the diagram...because it completely shows what is going on. When the valves are open all gases go through the outers...green line.
Thanks!
Received 1,817 Likes
When the valves are closed, the "straight-through" section is shut off.
Exhaust is always flowing through the inner pipes, but as it is running through the muffler baffles, most of the soot is deposited in the muffler leaving the tips clean. When you close the valves, the exhaust is all run through the muffler/inner pipes. When the valves are open, SOME of the exhaust is allowed to flow throug the outer pipes, bypassing the muffler and allowing soot (and a lot of extra volume) to exit unimpeded, causing the outer tips to turn black. The rest is still running through the inner pipes and still depositiong most of the soot inside the muffler.
Exhaust is always flowing throug the inner pipes, but as it is running through the muffler baffles, most of the soot is deposited in the muffler leaving the tips clean. When you close the valves, the exhaust is all run through the muffler/inner pipes. When the valves are open, SOME of the exhaust is allowed to flow throug the outer pipes, bypassing the muffler and allowing soot (and a lot of extra volume) to exit unimpeded, causing the outer tips to turn black. The rest is still running throug hthe inner pipes and still depositiong most of the soot inside the muffler.
At higher throttle openings, when the mixture is much richer (sootier), the valves will be open, allowing most of that sootier exhaust to exit through the less restrictive path on the outer pipes.
